Diode Laser Etching of a PCB. DIY From a to Z.
Published
Introduction: Diode Laser Etching of a PCB. DIY From a to Z.
3D-printers have opened endless possibilities for home production and rapid prototyping. Now you can easily create practically any model in a 3D-program and 3D print it. But until now, only few people have thought about the possibility to 3D print electronics for this or that solution (model).
Up to this day to make a circuit board for a prototype one had to pore over it with a soldering iron or to order a short production run. However, many of us can make it using a conventional iron and a laser printer.
https://www.youtube.com/watch?v=GjXhPRYOMzg
Though, this process is not very pleasing either aesthetically or technologically. In this article we would like to describe another method.
Not only any 3D printer but also any DIY Engraver will fit for it
https://www.youtube.com/watch?v=PiqIf3fK1Fk or a constructor of a makeblock plotter xy type https://www.youtube.com/watch?v=bDlq0_BuEyM
By the way, you can install a diode laser almost on any 3D-printer, setting it as an addition or in place of the extruder. Diode lasers are small in size and compact. Their relatively small power output compared with that of CO2 lasers is not a drawback in this case.
https://www.youtube.com/watch?v=WsqPBhB_acE
So, what does the process of the circuit board manufacturing at home or in the office look like?
Step 1: Bill of Materials
For this we need a copperized glass fiber plate, any dark vinyl film (any dark film that a laser can burn through will fit), iron chloride (sold openly in stores of chemical reagents) and, of course, a diode laser installed on a 3D printer. Its power output is not so very important, but we recommend to use a diode laser of more than 2W (2000 mW).
To install a laser on any 3D printer is very easy …
How to install it on an Ultimaker https://www.youtube.com/watch?v=soYh5Kyv4cs
and on a WanHao DuPlicator i3 https://www.youtube.com/watch?v=yf-uFAynGhM
So, let’s begin:
1. Create a circuit board model using any program of an InkScape type (inversion picture. Later, we’ll explain why inversion).
2. Convert it into the gcode.
Step 2: Cover
3. Stick the vinyl film onto the copperized plate of glass fiber.
Step 3: Engrave
4. Place the vinyl coated glass fiber plate onto the work table of the 3D printer, and turn on the 3D printer in the laser cutting / engraving mode.
5. The laser will burn on the vinyl film an inversion image of the pattern to be resulted.
Step 4: Chemistry...
6. Dissolve the iron chloride powder in water (do not worry, no chemical reaction will follow)
Step 5: Result
7. Put the glass fiber plate into the iron chloride water for 45-60 minutes.
The copper on the glass fiber surface, free of the film after the laser burning, will react with the iron chloride (copper etching chemical reaction) and goes into the solution leaving clean glass fiber in the contours of the inversion image.
Then, make holes for the necessary connectors with a small drill, or leave as is, and solder the connectors on top of the circuit board.
So, we have told you how you can create a small shop - laboratory for circuit boards manufacturing, using a 3D printer and a laser.
This technology is certainly not perfect and has several shortcomings, but it is efficient and can be used at home and small laboratories.
https://www.youtube.com/watch?v=Q39atHpMnfo
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    6 Comments
    I have made a number of instrument fascias using acrylic sheet using automotive, matt black spray that my laser etcher burns through easily. It has the advantage of drying quickly if laid on in one or two light coats (hold it up to a light source to check coverage between coats). In the case of the fascias, I gave a light spray with a white compatible spray over the etched areas to achieve professional quality fascias.
    I have no doubt that the same technique can be used for PCB etching but obviously, omitting the white spray part.
    I think this will go much better with a thin layer of black ink over the pcb. It will enhance the laser effectiveness and also demand much less power to do the same job. But neat idea!
    I personally get excellent results with the toner transfer method and that's using semi-glossy magazine paper. judging by images they don't look like sharp lines to me, I work down to 300mil with TT method. But neat idea and Thanks for sharing.
    Agree... toner transfer is a bit of a Mess... i never seem to get all the toner powder to stick... hoiwever the precision or DPI of a commercial printer seems alot better (mine is 300 dpi) and in your picture, it seems the precision isn't verry good.. But very nice idea and project
