3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dirt Cheap Areated Cloning System For Plants
A simple and cheap (practically free if you have this stuff laying around like I did)way to propagate cuttings requiring a little more attention.
Step 1Getting Started
Getting Started
To get this set up going you'll need
-fish tank
-plant light
-cups
-aquarium ariator
-tubing
-bubble stones
-tape
-cooling rack
-distilled water
-glass or similar for lid
To get this project underway you need to round up all the above. It's very simple, I was lucky enough to have most of it laying around. You'll have to cut the cooling rack down to size with some wire cutters. Place this in the bottom of the fish tank. The reason that I have this in there is for plants that have already rooted. They don't like sitting in water once they hit the dirt. With the system that I am using water collects in the bottom of the fish tank after awhile.
As you can see from the picture I have two peices of glass for the lid. This is for humidity, I have them taped together and they act as a door. This makes it easier when watering or doing whaterver with the plants.
Wash out your fish
17 comments
Jun 8, 2010. 6:12 PMNWindo says:
So you are rooting them in nothing but distilled water?
Jul 9, 2008. 10:45 AMbiochemtronics says:
This is a great project. I am impressed. But, I cannot think of any reason to use distilled water. Regular tap water will work just as well if not better. if it has a little chlorine in it then it would be even better. It may help control the algae growth. Distilled water can actually cause cells to shrivel up and die. In one of my biology classes we mixed distilled water with blood while looking at it under the microscope. When the distilled water hit the blood cells they instantly shrivled up and died. A repeat with regular water did nothing to the cells. Distilled water can have the same effect on any type of cells including plant cells. It will also kill fish over time. As for the question about why you put air in the water. Plant roots need both air (oxygen) and water to flourish. That is why over-watering a potted plant can actually harm the plant. They actually drown. I have never heard of using honey to root plants but I can see where it would help a lot. It would help control the nasty stuff and the sugar would be great for the plants. You might want to use a little soft drink. That would even add a little extra CO@ which the plants would love. The water may get a little nasty honey or soda but it is not going to hurt the plants. Remember - they normally grow in dirt - you can't get much dirtier than dirt. LOL Again - a great project. I am actually going to give this one a try. I will check back to see how the dark vs clear cups experiment comes out. Thanks for taking the time to shre this with us.
Jul 10, 2008. 8:31 AMbiochemtronics says:
I got so inspired by your instructable that I 1went home last night and started building my own aerated plant cloning system. As for the distilled water thing - now I can understand why you use it. Living in South Texas I know what a problem mineral buildup from water can be. However, your plants would still do better in something besides distilled water. The pond water idea sounds good, but I am not sure what effect the abundance of nutrients in the water would have on your plants. I know very little about succulents, but I do know that ferns do not tolerate fertilizers well. I am going to try bottled water in my system. I can get it in large square 3 gallon dispensers with a valve on the front. Well take care and thanks for the additional light/dark information. Keep up the great research.
Jul 14, 2008. 11:44 AMbiochemtronics says:
Don't worry about the distilled water. If you are adding some sort of plant food (even pond water) to the distilled water then it is not going to harm any of your plants. Pure, distilled water is not good for anything living - including humans. It is also mildly corrosive so it damage materials like metal or plastic pipes and concrete. However, if you add a few impurities like salts and/or baking soda (used in swimming pools) and it is fine. You wouldn't think it would be like that but it is. Just don't try to keep your plants in pure distilled water.
Jun 11, 2008. 9:12 AMBig Bwana says:
Nice it's like a small scale hydroponics, And about using a darker cup, covering the cup with foil / paint or something to that effect will also stop algae from taking over your water, this is common if you use fertilizers or growth / rooting hormones like IBA ... Dipping the ends in liquid honey before putting them in the water is also a good idea to stop fungus from showing up on the plant, this works on most hardwoods, infact I've found it to work better then most commercial chemicals, almost like the bees know what they are doing ... And temperature is also important if you want good rooting, try keeping it in about 21 to 26 degs C and if you need to heat use a bottom heating like an electric heating pad, the seed starter kits in wal-mart with heating pads are ideal for this .... And while growing Kratom is legal you know it's on the D.E.A. Drugs and Chemicals of Concern list, so it's only a matter of time until it is illegal to grow...(( just guessing your in the US )) but there is lots of plants that aren't... like morning glory's .........
Jun 13, 2008. 12:00 PMBig Bwana says:
The honey tip was from some old gardener I know, which they use to root lilacs with, So I figured why not try it, whats the worst that would happen ? A few cuttings would die, but not a one did, I can't say the same for 0.3% IBA rooting hormone treated cuttings.. Now I haven't tryed it on Kartom, but lots of other plants, even on cut herbs I bought at the store.. And there is more then sugar in honey, it seems to stop fungus from growing, and it really promotes the roots to form ... And don't waste your time with expensive fertilizers, I just use Plant Prod, 10-52-10 ( $6 will make a few hundred liters ) it's in most big box stores, and it's 100 % water soluble just mix it 1/2 strength for the first couple of weeks, after you have some roots formed..... And it's for the mum, dam I though it would work as a sedative on the kids ....
Jun 9, 2008. 7:45 AMEaglesNest says:
Can you explain why this helps the cuttings root faster? I've only ever stuck a cutting in water and then waited and hoped that it didn't die. :)
Jun 9, 2008. 8:20 PMEaglesNest says:
Interesting! I don't recognize that plant - do you have a list of plants that would do better with this technique?
Jun 9, 2008. 2:15 PMboxofish says:
Hmmm interesting, do you happen to know what the probability for rooting would be versus without the air bubbles by chance?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dnsnthegrdn
I just do what I do.
