Dirt Cheap Canon DSLR remote
 by nk dtk
FeaturedContest Winner
Step 3: Step three- finish up
Slide the tab over the end of the end of the 2.5mm connector and make sure it fits tight. when you apply pressure to the top of the tab with your thumb, it completes the circuit and commands the shutter operation. I can comfirm this works with my Canon T4i(650D). A better way to do this would be to cut off one of the 2.5mm cable ends and attach a momentary switch to the open connections. With heatshrink tubing and a store bought switch, the switch could look clean and professional, however, this instructable was made to show how i used the resources around me to rig together a make shift switch as an emergency.
SMHLonWlf says: Jan 23, 2013. 2:47 PM
This is a good alternative to buying the 'official' release switch for these cameras, and I suggest replacing the pop-tab with a n.o. pushbutton that you'd find in various electronics.
Hope you found my comment to be constructive, I haven't logged on in ages
spyder461 says: Dec 27, 2012. 5:57 AM
Thanks for the information. I never would have though that the remote would be a simple switch. Back to the good old days where things are done simply so these kind of emergency solutions are possible. Well done.
onemoroni1 says: Dec 23, 2012. 4:14 PM
Thanks for sharing your ingenuity. My wife just bought a T3. I haven't looked at the remote release socket, but I bet it is the same and If it is I would like to do the upgrade you suggested. Beats laying out money for such a simple trip circuit device.
obviousgenius says: Dec 23, 2012. 11:26 AM
The simplest things are the best. Exceptional observation on your part. I did something similar in terms of simplicity. Check my Instructable.
darksb3r says: Dec 23, 2012. 10:29 AM
Great idea - thanks!
stackerjack says: Dec 23, 2012. 9:51 AM
Wel done. A simple solution to a problem. Not everything in the world has to be sooooo complicated that you cannot/don't want to/ don't know how to/ daren't use it.
"Merry Christmas"
HeavyC says: Dec 22, 2012. 8:37 PM
I use this trick all the time! It's very clever. It's the same principle as firing a flash with a sync cord and a pen knife. MacGuyvering is the first technique every photographer should embrace.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
