Introduction: Dirt Free
I had a small garden bed that was not producing. When I tore it up I saw that it was full of pine tree roots that had eaten all the good stuff and made the PH of the soil off. Now I have a wheel barrow full of used up dirt to do something with. I also container garden, so every year I am paying money for DIRT! Even the organic compost is so UN-impressive, full of rocks and bark, I have plenty of those already. I want to recycle the dirt instead,free yummy dirt to use each year.
Supplies:
perforated pipe. I found it is cheaper then the other pipe, and already has holes!
Barrel , garbage can , whatever you have lying around
Drill plus bit
Small container
Bricks, Rocks, 4x4, ect.
Dirt
Worms
Food scraps
Paper or leaves
Step 1: Pipe
Cut the pipe to fit the barrel or container. It is best if all the holes are covered with dirt to keep bugs out and worms in .
Step 2: Install
Drill some drain holes in the bottom of container .Place pipe in center of the container. Fill with used up soil.
Step 3: Catch Water
Place the container up on 4x4, brick, rocks ect. Insert a water catcher, mine is the container salad greens come in. You can pour this water back in the container, or when it starts getting compost you can air-rate it for tea for your plants.
Step 4: Worms, Food.
Place worms in pipe. I dug some up and used those. Then layer shredded paper or dried leaves with veggie scraps until full, replenish it when needed. Give the dirt some water till damp.
Step 5: Cover
Cover the opening to keep smelly bugs out. Next year remove the dirt and switch it with the used up dirt from last years container's. And repeat . Good bye $$compost and bags of dirt!
Gardening Contest 2017
