Disappearing TV with Pop Up TV Lift Mounted Behind Furniture
This is a cool home improvement project that only took us about 30 minutes to do.
The situation:
The owner of this home had a flat panel TV in the room, sitting on top of a rustic wood cabinet. He only watched it occasionally, so most of the time it was just an eyesore to him that was blocking part of his window view. He thought about getting (or making) a Pop Up TV cabinet to hide the TV, but he did not want to replace or modify the furniture he already had in the room.
The challenge:
Find a way to hide a 42" TV behind the existing cabinet, even though the cabinet and the window sill are only 24" tall!
We solved the problem by using a TV lIft system to mount the television BEHIND the existing cabinet. The lift system is made by Nexus 21, and is only 23" tall. It could also have been mounted behind a sofa or other piece of furniture. This model comes with a remote control and a universal mount for TV's as large as 42".
The Result:
Our installation involved no carpentry work and no need to buy a special pop up TV cabinet. Now, instead of a "TV Room", the home owner enjoys his "Living Room", with nothing to block the view outside his windows. He also got a cool new automation feature. When he pushes the remote control button, the TV quietly raises up from behind his cabinet. Another button-press and the TV completely disappears behind the cabinet.
Cost of the project:
The TV Lift System used for this project costs $1,350. There are less expensive lifts on the market but, surprisingly, there are also a number of MORE expensive ones as well (prices range anywhere from $500 to $3,500). The home owner specifically chose this television lift system because of its strong warranty and because it was the least expensive of the high quality lifts that are made in America. He considered a few systems that had prices of $500 to $700, but found that they were all imported from Asia, and did not carry a strong warranty.
If you want to check it out, the Nexus 21 website is: http://www.TVLift.com.
Step 1Materials Used
Materials Used
Pencil
Tape Measure
Level
Philips Screwdriver
Cordless Drill
Allen Wrenches (included in TV lift package)
Small piece of 1/2" thick plywood, painted black (not shown in this photo)
Model L-27 TV Lift System from Nexus 21
42" LCD Flat Panel TV
25 comments
Oct 4, 2011. 10:12 AMim3733 says:
I would take it a step further and install a "door" in the top of the cabinet that opens while the tv is moving, and have the area around the tv's down position to be padded. This prevents the tv from being damaged while its lowered if someone (like me) ends up falling into the cabinet, by being in the cabinet, instead of behind it.
Aug 2, 2010. 12:40 AMzack247 says:
really cool! too bad us 'iblers haven't figured out how to make our own yet...
Oct 4, 2011. 10:09 AMim3733 says:
figuring it out is the easy part. someone just needs to build and post it.
Aug 2, 2010. 5:54 PMfrydaddy says:
This was a fine instructable. I've been looking for this type of installation where the furnature didnt have to be modified. thanks.
Jun 1, 2010. 9:26 AMpop up tv says:
This project really saves space especially at homes with limited space. it shows the step by step procedure on how to build a TV lift. It also demonstrates how to combine the materials with the piece of furniture to create a good TV lift.
Aug 1, 2009. 2:01 PMgewthen says:
Not really a do it yourself job since your using a complete kt without any real work. I'd like to see a version where the lift is constructed.
Aug 3, 2009. 10:28 AMgewthen says:
Ahh. Didn't know one had to modify the furniture, which really won't work for antiques. I can understand how some people would need a more detailed step by step guide, but when I think of DIYs, I think of from scratch or mostly from scratch jobs. Your next Instructable, would probably require cutting into cabinets, which is getter closer to the ideal "from scratch" Instructable. It could be valuable to anyone concerned about installing a lift and messing up their cabinets.
Mar 21, 2009. 8:22 PMcrazycommanche=US= says:
i could defintely designone of the se for under 30 dollars depending on how heavy the tv is all u need is a guide sytem locking mechanism and 1 actuator to be the lift scrw psyin 1326 or whatever
Jul 19, 2009. 7:51 AMpleabargain says:
I'm looking for that instructable now! My TV is about 6" deep and weighs about 35lbs.
Jul 14, 2009. 11:36 AMxerxesx20 says:
Bloody hell that's a lot of money, what's wrong with using a strong linear actuator or a small rack and pinion?!
Mar 9, 2009. 5:44 PMChicken2209 says:
SAM!!!!!!! i miss sam but that was a good movie I give this project 5*
May 7, 2009. 8:01 PMfrickinchance113 says:
i am reading it...
Mar 21, 2009. 8:24 PMcrazycommanche=US= says:
i love that movie
Mar 11, 2009. 4:10 PMChicken2209 says:
Yes No No I'm kinda mad where the kid gives him the dog It just seems so unrealistic, I mean hes like daddy cant take the puppy but he doesnt try to resist Sam
Mar 18, 2009. 12:56 PMImportAdvantage says:
Pretty cool and saved sometime having to alter the furniture. Another way is to build a simple box and cover it in fabric or leather as we do on our site. Your welcome to look. If anyone has custom cabinet questions where you need our advice, happy to lend my 10+ years of experience! Rob www.ImportAdvantage.com
Mar 12, 2009. 8:40 PMcantthinkof bettername says:
This project would be cooler if it showed how to mod an old treadmill or garage door opener to do this or something.
Mar 10, 2009. 8:45 PMbeauwalker23 says:
Um, this is cool. If you want to spend a $1400 bucks to hide a TV. Also, all you did was show us how to install it. Is that not in the instruction book? I was didipointed to find out that you did not make it, you just ordered it and hooked it up.
Mar 10, 2009. 8:24 PMphapboy says:
this is awesome! I want one!
Mar 9, 2009. 6:18 PMTysto says:
Nicely done, but shouldn't this be pretty well covered by TV lift kit instruction manual?
Mar 9, 2009. 4:10 PMlemonie says:
It's good, did you see this one? Different job but yours reminded me of it.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:hiddentvguy
