3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Disarming Game
Disarming Game
This disarming game was made for my daughter Tika’s Traditional Theme day (TTT-day). This year’s theme was “James Bond meets Austin Powers meets Chuck” (two International Men of Mystery and one All American Nerd). An activity around disarming an (obviously fake) bomb was the apotheosis.
Check out this video on the result:
The object of the game is to cut the correct wires to stop the clock in time. During the day they got several coded messages on some of the colour codes used on the wires (but not all and some confusing). Cutting one of the four correct wires results in one of the red LEDS switching off and one off the green switching on. Cutting a wrong wire switches on an orange LED. Reaching four green LEDs switches of the clock and switches on a voice recorder to play. For some scare the recorded message warns an explosion to be imminent, followed by a counting down fading as the bomb switches of completely with only seconds to spare ;-)
When four orange LEDs would be switched on ................ well nothing happens actually. After all the kids were supposed to win. Actually they cut only one wrong wire and the orange LED happened to malfunction (loose connection), but that did not diminish the fun.
I made this for a one time use and kept things as simple as I could. I also kept this Instructable very simple, just the parts list, an explanation on the circuit diagram on the building. If you have some basic knowledge of electronics, it should set you on your way if you wish to make your own version. If you have some serious knowledge of electronics, you can probably improve it significantly.
This also an entry in Kiteman's "International-Go-Pro-Challenge". Check it out!
Step 1The parts
The parts
A battery operated quartz clock, a fitting battery and a separate battery holder for the battery
A 12V battery
4 red LEDs
4 green LEDs
4 orange LEDs
5 diodes
Two 1 kOhm resistorsA 2.5 kOhm trimpot
A 12V relay with single or double SPDT switches (double makes adding an optional blinking indicator LED easy)
A 2N2222A transistor or any NPN general purpose switching transistor capable of driving your relay
Some colour coded single stranded wire, at least 8 pieces of 20 cm length (to be cut). A piece of ethernet cable is a good source.
A breadboard or some other way to build the circuit and some more wires to make connections.
Some wires with alligator clips to connect the clock, its battery and the optional voice recorder
Some tape to attach or mask parts
Optionally:
A voice recorder that plays back when switched on. I used a small sound recording module used for greeting cards product ID 191184 at Conrad
A blue blinking LED And a another 1kOhm resistor
Something to put everything on or in. I used a case with a board cut to fit and to hold the 12 V battery
24 comments
Jan 18, 2012. 3:44 PMB3rker says:
Ik moest lachen met "Ow Ow Ow! Niet aan trekken"
hopelijk is de bom niet zo broos ;)
Oct 6, 2011. 8:45 PMAT says:
Very nice! I love it. Just don't take that on the plane with you! ;-)
Oct 6, 2011. 3:50 PMDasFitz says:
Be good for those search and destroy missions for you cod movies or paintball and airsoft missions
Oct 2, 2011. 6:36 AMTreknology says:
Hint: To make it modern-day realistic, use a digital watch or clock with a randomly set and inaccessible alarm time. Zero isn't always blast-time.
Sep 28, 2011. 6:46 AMantoman11 says:
Bring this into an airport for the lulz
Sep 29, 2011. 7:20 AMnjamspike says:
bad idea
Oct 1, 2011. 8:56 PMantoman11 says:
That's why it's for the lulz
Once one of them stopped me after seeing my diy mintybooster http://www.ladyada.net/make/mintyboost/
I was allowed to go through with it after showing them how it worked and what it did though :D
Sep 29, 2011. 4:10 PMGarebear350 says:
You should post how to incorperate this into anthor instructables project. That way you could have many more expansion opritunities. Here is the project http://www.instructables.com/id/Prop-bomb/
Sep 30, 2011. 6:07 AMGarebear350 says:
I'll post an ible on it in about a month. It will incorporate that project that i posted a link to.
Sep 29, 2011. 9:20 AMDieCastoms says:
Loved seeing everyone back away suddenly :D Yes, I am sadistic, I am sorry...
I love this thing! When I was a kid, my 'favorite' thing to do with old wires was to wrap them around ... anything round ... pencils, screwdrivers, anything, and then take the coiled wires and build "bombs" like Wile E. Coyote.
Your project looks like a lot of fun. With more robust wires and "bullet connectors," it could be made reusable, although you might want to switch the wires around for each use. Also, if four green LEDs can trigger the voice and stop the clock, could four orange LEDs trigger a disposable camera flash? There would at least be a somewhat audible pop and a flash when you fail :P
I would leave out the four red LEDs and distribute the other LEDs around randomly so that when you do cut a wire there isn't quite such an obvious indicator.
Also, you mention they did cut one wrong wire but the orange LED didn't light? Did they win with a passing grade of 75% or what? What if they got two wrong and two right? three wrong?
Awesome dad, Awesome project!
Michael.
Sep 29, 2011. 2:48 PMAce Frahm says:
What could possibly go wrong?
Sep 29, 2011. 9:18 AMsqeeek says:
Haha, need to leave one of these sitting in a bus sometime XD
Sep 28, 2011. 7:21 AMynze says:
Great project!
Sep 27, 2011. 12:18 PMkenyer says:
zo cool hoe die kids reageren alsof het een echte bom is. :)
Erg leuk project!
Sep 26, 2011. 3:13 PMrandofo says:
You are probably the coolest dad ever... just sayin'...
Sep 26, 2011. 4:55 PMpaganwonder says:
Without a doubt. The bar is now very high...
Sep 26, 2011. 3:56 PMwilgubeast says:
Seriously.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
141
Author:masynmachien(land, sea, air and space)
My main hobby is developing creative workshops for children. Since several years now I have been organising those, mainly voluntary at the school my daughter is attending. My workshops most often invo...
more »
