3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Disassemble Seagate External Harddrive Enclosure
Step 5Utilize the Hard Drive
Congratulations, you now hold in your hand a hard drive Seagate probably didn't want out of its encasing. Nonetheless, it's a standard IDE hard drive and can be used as such. The enclosure should also be usable for future use. Just put your hard drive of choice in and put the enclosure back together.
EDIT: A good point has been brought up in the comments - if you do decide to put a different drive in the leftover enclosure when you're finished, be aware that you may run into compatibility issues. Besides the fact that the power source in the enclosure probably won't be sufficient to run higher capacity/rpm drives, you may run into problems with the board recognizing the drive, etc.
3 comments
Jan 27, 2010. 3:20 PMgerlin says:
Caution when installing a new drive in this external enclosure:
The drive-side of the metal box shield has some tabs that make contact with circuit board screws on the drive - a different drive may have board screws in different locations and you do not want the tabs contacting any circuitry.  The tabs are easily straightened inwards to avoid unwanted contact.
Mar 2, 2009. 9:20 PMinst666 says:
Please change the title to a more accurate one: "Disassemble External Hard drive CASE". I was hoping to find a guide to disassembling a drive. I don't need the data. I simply want to see what goes on inside one.
Aug 13, 2008. 11:09 AMhynee says:
I haven't seen any comments in this guide regarding HD compatibility. Mine came out with the Cable Select jumper selected (second from left), yours seems to have come out with Master (left-most jumper position). Trying all three of Master/Slave/Cable Select may help debug any problems.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MonkeyAgent
