3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Disassemble a Computer
In this Instructable, I will give a full documentation of how to disassemble a desktop PC, for parts. The specific computer that I will demonstrate with is an HP Media Center PC m7640n with a dead motherboard. Every computer is different, but this is a general guide.
If you don't fully grasp what I mean when I am describing something, please refer to the pictures!
Picture Quality Notice (and HD pics!):
Due to the amount of pictures I uploaded, they are of lowmedium quality. Click the "[i]" in the top left corner of a picture, then click "original file: (3072x2304) 1 MB" to see the high quality HD pictures!
Step 1Unplugging
Unplugging
The first thing you do, is unplug every cable that's plugged in to your computer. That includes the following cables:
  • Power
  • USB
  • Firewire
  • Mouse
  • Keyboard
  • Internet
  • Ethernet
  • Modem
  • AM\FM Antenna
  • Cable TV
  • etc...
So pretty much just unplug every cable from your computer.
118 comments
1-40 of 118next »
Oct 18, 2011. 3:10 AMMRedu says:
Great guide to salvaging pc parts from a computer thanks!
Sep 3, 2011. 8:17 PMkt2112 says:
"No disassemble" - johnny 5 lol :)
May 9, 2009. 3:03 PMwhatsisface says:
Preferably not a carpet, they can cause static build up which kills components. Best to be on some kind of desktop work surface or antistatic mat, using an antistatic wrist band.
May 9, 2009. 3:22 PMcyrozap says:
This is true. I saw how he was disassembling it on a carpet and thought: lots more dead components.
May 8, 2011. 3:02 PMkaterlyn says:
I did not read ALL the comments, did I miss where it's mentioned where you get the copper to recycle? Someone mentioned they used to do that where they worked, and someone else mentioned it is too time consuming or toxic. ??
May 13, 2009. 10:46 PMReCreate says:
You have Been Lucky,Sadly,I Killed 2 main boards and 4 peices of ram with carpet. If you ground yourself,your not doing anything,you are just grounded,but not the carpet
Feb 12, 2010. 10:15 PMdarkclaw42 says:
 I am too. Ive gotten, literally, over twenty computers from a country club. I disassembled them ALL on my carpet. None of the components fried that were still working when I pulled them out. Extremely lucky bunch we are!
May 15, 2009. 7:40 PMReCreate says:
Well you'r Lucky,Very Lucky,Do NOT think that that is a myth,it is NOT,And it is a VERY common problem,Why do you think they sell those stuff in antistatic bags?
Jul 23, 2009. 9:16 AMtanmanknex says:
I fried my built in video card because i disassembled it on carpet... I haven't bothered to get a new one because i have another computer, luckily, and there wasn't much good things on there anyway.
Jul 23, 2009. 9:48 AMReCreate says:
Well that is proof.
Jul 23, 2009. 11:26 AMtanmanknex says:
Unfortunately...
Jul 23, 2009. 11:36 AMReCreate says:
yeah
May 5, 2011. 12:24 PMfmuhammed says:
Oh My God. I can't describe my impression in words. Thank you very much. I was struggling to remove Hard disk from this machine for 2 hours and totally gave up fed up. But thanks for Istructables. I disassemble this PC within 5 minutes. It was easy as Pie. Thank you again. :)
Apr 2, 2010. 8:29 PMYerboogieman says:
That's not an ethernet card, It's a 56k modem. The ethernet is built into the mobo.
Feb 12, 2010. 10:13 PMdarkclaw42 says:
 Darn, you beat me too it. I was browsing through instructables and had noticed there were few computer guides, now there's one more added!
I might just do the opposite, if you arent already planning. Assembly of a computer. Whew!
Oct 24, 2009. 12:29 PMcoldfiregh says:
would you be very kind to add how to take out the processor and replace?
Jan 8, 2010. 8:53 PMANDY! says:
Take the cooling stuff off, find the little lever, pull it open fully, take chip out. thats it prob.
Oct 26, 2009. 4:22 PMcoldfiregh says:
there is a first time for everything; isn't it? the quest for sometime takes people places they never thought about a second ago; anywayz i already figured it out; it implies zero pressure application and release of a latch; thanks very much for the wonderful post
Feb 10, 2010. 10:44 PMgorrillamcdouglas says:
I don't know if you'll have this problem taking the processor out or not, but for the benefit of everyone else...
If the Processor is stuck to the heatsink, there are a couple ways to get it un-stuck.
First, twist it gently but firmly, avoiding bending the pins on it. If this doesn't work, soak the heatsink and processor in Isopropyl alchohol(70% or more). After a few minutes, take unflavored dental floss and run it inbetween the processor and heatsink. It should come off. But always be sure not to bend the pins and don't use rubbing alchohol below the 70% concentrate.
Aug 28, 2009. 4:28 PMIncrediblyCondensedBlackMatter says:
you dint cover how to remove the processor from the board but otherwise this is really good. : D
Aug 28, 2009. 5:36 PMSolderguy says:
Yes he did, in step 15 he said, "The motherboard has seven screws holding it to the frame, which are indicated by large white circles around them. Remove those seven, then lift the motherboard out of the frame." You need to read, and not stare at the pretty pictures. :P
Oct 15, 2009. 2:09 PMIncrediblyCondensedBlackMatter says:
HA! pwn'd by the AUTHOR! XD anyway, the motherboard and the processorare two totally different components.
May 21, 2009. 8:49 AMAdrianb says:
Is it wise to lay all the components on a carpet? I'd suggest using a clean (!) wooden desk or something. For one, the carpet is dusty and, although I'm completely not certain about the probability, the carpet may have static electricity..
EDIT: Oops, didn't read correctly.. You already warned for static electricity!
Adrian
May 21, 2009. 5:34 PMdombeef says:
How do you edit a comment?
he hacked the instructables comment database to add his edit, Duhh lol no
May 22, 2009. 3:29 PMdombeef says:
Ok but, Nevermind
Jun 29, 2009. 8:29 PMmemyselfand1 says:
Blimey! How many pictures did you put in this?
Jul 19, 2009. 9:31 PMtanmanknex says:
and that's what makes them good. good job!!!;D 5*
Jul 4, 2009. 3:41 AMiProton says:
Is it possible to disassemble and reassemble it as a Network attached Storage device? :P
Jul 4, 2009. 11:09 AMiProton says:
That would be top of the pilot aceage :P
Jul 3, 2009. 1:58 AMdingus234 says:
Good Job. A lot of work has gone into this. By the way the 'Ethernet expansion card' is actually a dial up modem. :-)
1-40 of 118next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:Arbitror(Check out my blog!)
One of my favorite hobbies is dismantling electronics, then either combining them together to create something new, or adding components to make them better. I also like gadgets, whether it's taking t...
more »
