3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Disassemble a Computer
Step 2Outer Shell/Casing
Outer Shell/Casing
  • last photo ←
Now that your computer is fully unplugged, move your PC to a clean work space, preferably a carpet. The carpet is better than tile, because screws and other small parts will roll around.
NOTICE:
If you are working on a carpet, about every five minuets touch something that is grounded (Sink faucet\pipe, wire coming from the ground part of a wall outlet). This is so you don't shock your motherboard or other parts.
First off, unscrew the four screws on the back of the computer. On most computer cases, there will be large knobs that you can unscrew by hand or by screw driver on the back-right side of the computer. The left side has small screws because on that side you can't access much on the inside.
Once the screws are removed, you can remove the side panels. On most computers, they just slide off. Start with the left side panel (the side that once had the knobs), slide it towards the back of the computer. Now you can remove the left panel. Just like the other one, slide it towards the back of the computer.
Please refer to the pictures if you are confused!
1 comment
May 21, 2009. 8:49 AMAdrianb says:
Is it wise to lay all the components on a carpet? I'd suggest using a clean (!) wooden desk or something. For one, the carpet is dusty and, although I'm completely not certain about the probability, the carpet may have static electricity..
EDIT: Oops, didn't read correctly.. You already warned for static electricity!
Adrian
May 21, 2009. 5:34 PMdombeef says:
How do you edit a comment?
Jul 23, 2009. 11:36 AMReCreate says:
he hacked the instructables comment database to add his edit, Duhh lol no
May 22, 2009. 3:29 PMdombeef says:
Ok but, Nevermind
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:Arbitror(Check out my blog!)
One of my favorite hobbies is dismantling electronics, then either combining them together to create something new, or adding components to make them better. I also like gadgets, whether it's taking t...
more »
