Unfortunately, the gauge of the wire inside the transformer was too large to use for a guitar pickup, but it still is good enough for an electromagnet or whatnot.
Remove these ads by
Signing UpStep 1Tools.
1 pair of needlenose pliers
1 can of industrial strength repetitive task preparedness
sorry for my english i'm french beginer ^^
i have and it works
i only used one of the 2 formers and made an autotransformer to change 16vac to 12,9,7,5,3,2, by the tappes of 3,5,12 3-5 =2v 5-12=7v.etc
a standard 48x28.5mm winding is 9.47turns per volt.(10-13va/w)
20t-v 5va mini transformer.
240v is about 2200 turns(approx) of 0.125mm wire.(10-13va)
The output on the block staes 21V-500ma to charge an 18 volt battery or possibly run the tool directly.
I have seen; 12 and 16 volt transformers, about the same physical size, but is there any way to use the existing components to determine what transformer they are working with?
Thanks in advance, all replies accepted.
Cymbalta
Other then hooking them up to the proper input voltage, and measuring the output, and then attaching a load to the output, I don't know of a another way, offhand.
L
L
