Who wants to transform themselves into the victim of the world's glammest shark? Well, really the question is, who doesn't?
With this little make, you can have your very own glittery predator to feast on your flamboyant cranium.
What you'll need:
Step 1: Assemble the foam core and slipcover with Disconium
Create Shapes for the Foam Core
  • Trace a loose fitting knit cap and draw a shark outline around it. Cut that out and trace another piece, leaving off the fins. Cut that out as well.
  • Cut out separate triangles for the dorsal and lateral fins. Cut a triangle (rounded at the top) to be an upper-lip/nose.
  • Pin all the pieces together with safety pins to test the fit...adjust shapes accordingly.
Prepare and Assemble Disconium Slipcover:
  • Trace the larger foam shark piece onto the disconium fabric.
  • Cut two pieces of the traced shape, leaving around a 1/2  to 5/8 inch seam allowance around the edges. Repeat for the three fins. For the upper lip do the same, except cut only one piece.
  • With right sides together, sew the two largest pieces of disconium together, leaving open the mouth edge and the space for the dorsal fin. Sew on the upper lip - the rounded corner should be placed where the two large pieces meet at the top of the mouth. Turn right sides out.
  • Sew the covers for the fins and stuff them with foam pieces.
  • Stuff the large foam pieces into the fabric slipcover. On the inside, hand sew the upper lip and two side pieces together at the corner.
  • Cut slits in the fabric to correspond with the fin slots in the sides of the foam. Hand sew the fins into the slots on the sides and on the top.
  • Reinforce any joins in the foam with hand sewing as desired.
Step 2: Teeth and Bloody Mouth Liner
Create the Mouth
  • Cut a long rectangle of the red velour fabric, the length of the circumference of the hat opening and the depth of the hat from the opening to the crown.
  • Cut a bunch of white triangles out of the felt and pin them to one of the long edges of the fabric at regular intervals. The pieces of felt should be pinned to the right side of the fabric and the points should be facing toward the opposite side of the fabric.
  • Baste the teeth on and sew the two short ends together.
  • Turn the fabric tube inside out - right side and teeth on the inside.
Attach Mouth to Shark
  • Pin the tube over the outside of the head opening lining up the fabric edges. The teeth should be invisible in between right sides of the velour and the disconium. Sew the edges together.
  • Turn the velour right side out and sew the top seam in the same orientation as the dorsal topline.
  • Hand sew the top seam to the foam at the top inside of the hat at the corners, or as desired.
Add Eyes
  • Cut two back felt circles and two slightly larger white felt circles.
  • Sew or glue the black felt on top of the white.
  • Sew or glue the circles onto the hat in the position of the eyes.
Step 3: Shark Attack
Once you have completed the hat, you are ready to launch an attack. A very groovy, disco attack.
The most appropriate place to launch a disco shark attack in the metro DC area is, of course, Nationals Park, in support of Roger "The Shark" Bernadina, the nation's most beloved backup outfielder. Even Abraham Lincoln loves The Shark!
But you may opt for another appropriate venue, such as a beach or a nightclub. Also perfect for special holidays, like Halloween or Shark Week!
Jur says: Oct 1, 2012. 4:16 AM
Have you been in Stockholm recently?
There is an ad in the subway with a dude wearing a hat just like that one!
(I'll try to get a picture if I can)
When I saw it I really wanted to make one, and now I can =D
Thank you!
HenryBasenji (author) in reply to JurOct 1, 2012. 9:03 AM
The Disco Shark Hat has thus far been confined to the US but is happy to learn it has some cousins abroad, and may soon have more!
Jur in reply to HenryBasenjiOct 1, 2012. 9:16 AM
I found a picture on their website instead, this is what the Swedish (Disco) Fish looks like!
Screenshot from 2012-10-01 18:12:01.png
HenryBasenji (author) in reply to JurOct 1, 2012. 10:02 AM
Oh man, I might have to make disco shark gloves now. Mine would be more functional with space for the hands in the back fins...
bobster88 says: Sep 27, 2012. 10:23 PM
lolz at ur hat.
Penolopy Bulnick says: Sep 25, 2012. 10:58 AM
I can't think of a better fabric to make a shark hat out of than disco fabric!
HenryBasenji (author) in reply to Penolopy BulnickSep 27, 2012. 5:31 PM
I suppose that sharkskin would technically be 100% more appropriate, but certainly 100% less fabulous.
scoochmaroo says: Sep 26, 2012. 10:57 AM
Ha! I didn't realize that was you on the BetaBrand site! Great build, and thanks for sharing it here. I've got four discolab projects that need to be posted still. . .
HenryBasenji (author) in reply to scoochmarooSep 27, 2012. 5:30 PM
Yeah I still have a ton of the fabric leftover. What to do, what to do?
ohforgodssake says: Sep 27, 2012. 8:56 AM
Good one. It looks like a tuna, a very hungry tuna.
HenryBasenji (author) in reply to ohforgodssakeSep 27, 2012. 5:29 PM
zombie tuna loves braaaaaaiiiiiins
MMoyce says: Sep 25, 2012. 7:38 AM
AWESOME 'ible' 4.5/5.0 stars :-D
Pixie Puddle says: Sep 25, 2012. 4:56 AM
thats wicked, awesome make, cheers for sharing, :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
