loading
Step 6: Build the interface circuit
Using the following schematic, build the circuit to interface the Arduino to the Datalogger.
it would be cool if it could log data onto the tape itself. I'm considering doing a bit of research into converting a VCR to store data on VHS tapes. Nice instructable.
the beta units if u can find 1 will work even better. vcr will still record if u use a vcr hook up. recieving the data will be a bit problematic tho.
also, what type of 10k resistor do you get ? Is it the one with 1/8 watt, 1/4 watt, or 1/2 watt?
or 3/4 or full watt type
any of those should work
i was thinking of an analog datalogger using the tape...
so what value of the diode do you get!?!?
doesnt matter
What exactly is it logging?
In this case, breathalyzer data. But, it can be modified to log any analog sensor.
could you use it to log position data from an incremental position encoder? (like on a cnc)
I don't see why not. I actually didn't make the datalogger itself. I bought it from here:<br/><br/><a rel="nofollow" href="http://www.sparkfun.com/commerce/product_info.php?products_id=752">http://www.sparkfun.com/commerce/product_info.php?products_id=752</a><br/><br/>They have full documentation. You should be able to log most anything so long as you want it on an SD card.<br/>
Quote "Two text files should appear called _ and . You want to open them and configure it to have the following settings " somthing is WRONG with what is NOT in this sentence. What are the settings?!?
Oh yeah... I forgot to finish that. Basically, you want to open the text file and keep the default settings for serial communication. Sparkfun has documentation about configuring the datalogger on their site. I'll fix that tomorrow.
thx
It would be cool to use an open PWM pin of the Arduino and hook it up to the input of a VCO, and connect the output of the VCO to the taping mechanism in the recorder so you can tell how much someone is intoxicated by the pitch of the tone.
About This Instructable
17,092views
30favorites
License:
Bio: My name is Randy and I founded the Instructables Design Studio. I'm also the author of the books 'Simple Bots,' and '62 Projects to ... More »
More by randofo:Mad Scientist Extension Cord DIY Life-Sized Cardboard Cutout Secret Drawer Lock
Add instructable to:
