Discrete USB Charger for MK7 Golf GTI
3,321
14
Posted in TechnologyElectronics
Introduction: Discrete USB Charger for MK7 Golf GTI
I love adding discrete upgrades to my vehicles, and USB chargers are always on the top of my list of accessories.
While the photos are specific to my GTI, this can be done on any car/motorcycle/boat/etc. The only change is finding the right fuse to tap into.
Overview:
  1. Find fuse to tap
  2. Connect lead of fuse tap to 12V -> 5V converter, and ground to ground
  3. Plug-in fuse tap and phone charging cord
  4. Charge!
Parts list:
Total = $31 ($51 with mount)
Tools (for MK7 GTI):
  • Flat head screwdriver
    • optional - small towel or cloth to cover screwdriver and avoid possible scratches on the dashboard
  • Needle nose pliers
  • Small crescent wrench
  • Soldering iron or crimp connector
  • Electrical tape or heat-shrink tubing
  • Optional - multimeter
Step 1: Find Fuse to Tap
For more information on the MKVII Golf fuse box check out this post:
http://forums.vwvortex.com/showthread.php?7072478-...
For the MK7 Golf, we will use the 7.5 amp fuse mentioned in the link. This fuse switches on and off with the ignition and is rated up to 15 amps.
It's always advisable to test the fuse with a multimeter to be sure it does what you want. Set the multimeter to 20V DC, and put one end on the metal bit of the fuse, and the other on a ground (unpainted frame or bolt).
When you turn the car on it should read between 11.7-13.5V, and turning the car off it should be 0-0.03V.
Step 2: Assemble the Fuse Tap and Converter
The mini fuse comes with a 2 or 3 amp fuse which is plenty for a phone, and also the max output of our converter.
Fuse taps only have a hot (+) wire since all electronics are grounded to the frame of the car. This way the ground (-) can be easily connected to a bolt or piece of unpainted frame.
Simply solder or crimp the red (+) wires together. Be sure to cover the connection with heat-shrink tubing or electrical tape.
Step 3: Plug It All in and Enjoy!
The interior fuse box is almost always located under the dash to the left of the steering wheel. Mine is behind a pull-cubby that pops out cleanly with a bit of wiggling and tugging. I also removed the side panel to run the wire along the A-pillar. The side panel has three tabs that snap it in place.
Once you've located the fuse you want to tap, pull it out with the pliers and insert it in the slot next to the provided fuse.
Next, plug your fuse tap into the same spot, and tuck the wires away. Once you have it all plugged in, turn on the car and test it with your phone. Then, turn off the car and make sure that your phone stops charging.
Snap all the panels back in and admire your work!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    3 Comments
    Hey, thanks for the instructable! Any suggestions on how to get the side panel off without damaging the panel or breaking the clips that hold it in place?
    I'm pretty sure I put a towel around a flat head an s pried on the top, middle, and bottom.
