3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Display case with unique Background Lighting
I will demonstrate one way to "illuminate" something in a deep display case, while preserving it's integrity and keeping it as safe and preserved as possible..
Step 1Planning, calculating Resistor values & arrays
Although one can (and should, at least a few times) use Ohm's law (one of the pictures below) to calculate resister values for LED's it can get a bit "odd" if parallel lines are used...warning, ALWAYS use segments of parallels, each with it's own resistor.   For my purposes here, because of some unknowns and the complexity of the number of LED's and types I was using, I decided to use THIS calculator.
With the calculator you will still need to know
#1:Source voltage
#2: diode forward voltage
#3: diode forward current (mA)
and finally #4: the number of LEDs in your array.
The calculator will give you several choices to pick from many times.
8 comments
Jan 22, 2012. 6:46 PMduggerpato says:
Does your profile description say you're older than 21? A little binary reference for part and full time geeks out there? ;)
Jul 18, 2011. 4:43 PMChrysN says:
Cool case! That's a great T-shirt I can see why you want to preserve it.
Jul 17, 2011. 11:32 PMiceng says:
Working and looks good.
I await to see the wonderous colored art you place in to the display.
A
Jul 18, 2011. 10:19 AMiceng says:
Now I remember you did type so.
T-shirt will do very well under UV.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
137
Author:Goodhart(Old as the hills...)
I am, most definitely older than 00010101 and to put it simply, still curious about nearly everything :-) I then tend to read and/or experiment in those areas - when I have the time... My two "spe...
more »
