3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Disposable Camera Ring Flash
Build a disposable camera ring flash. Disposable cameras are discarded after the film has been removed. Photo labs often have boxes of them under the counter, waiting to be recycled. If you ask nicely, you can often get more than enough to experiment with. Try to get at least six for this project, all of the same type.
Step 1Build It
Build It
Materials:
10" Cookie tin
6" Metal dog bowl (Dollar Store)
Disposable cameras
Radio Shack AA battery pack (with built in switch)
RD616 wireless flash trigger ($20 Ebay - search: "flash trigger 16 channel wireless")
Surgical tubing
Old tripod plate
Broken door cloths hanger
3.5mm phone jack
Packing Tape
Velcro
Wire
Bolts
Carl Vogt's $5 Photo Slave:
SCR 400 Volts 4 Amps (NTE5457 or Phillips C106D)
1 meg ohm 1/4 watt resistor
.05uF 400 Volt capacitor
Perf board
Solar cell from a dollar store calculator (WARNING: Dollar stores often sell calculators with fake solar cells)
Tools:
Nibbler (Radio Shack)
Punch (or nail)
Drill
File
Screwdriver
Soldering iron
Solder sucker
Wire stripper
Hot glue gun
Multimeter
Alligator clips
63 comments
1-40 of 63next »
Jul 7, 2011. 11:18 AMetw says:
Interesting project. Currently playing with disposable flashes myself. The only thing I had trouble with is the Carl Vogt trigger. That only seems to work when I leave out the capacitor.
The photocel should be sufficient as it seems to come from the same type of calculator that can be seen on Carl Vogt's project ;-)
Jul 9, 2011. 6:15 AMetw says:
Thanks for yr advice. Yes I did test it and it does produce about 4 volts inside for a well lit window. I have tried several capacitors, but apparently the only value that works for me is 0 Farad and even then it is not very sensitive. (no sensitivity for bounce flash and I really need to aim at the cell).
How much Volt should it produce to work properly?
Jul 14, 2011. 10:13 AMetw says:
Thanks, yes polarity is correct. The SCR is working (if no capacitor). Anyway I will try with another SCR. Thanks for the advice
Jul 16, 2011. 12:23 PMetw says:
Low and behold, a different SCR seems to have done the trick. Odd, as the first one I tried was fresh from the shop.
I must honestly say that I did not expect this, but as the circuit apparently is successfully built by many people and the cell, resistor and capacitor were not the problem, well, then it must be the scr ;-)
Strange enough I have used it (after the slave did not work) in another project where it performs fine. Perhaps less critical
Thanks for your valuable advice
Jul 16, 2011. 3:00 PMetw says:
Like to add that also the sensitivity is great, reacts to bounced flash at least 4 meters away, even when the voltaic cell is pointing the other way.
I am impressed
Apr 26, 2010. 5:56 PMrfowler643 says:
I played on your idea Divet and made a studio strobe.  It consists of your four disposible camera flashes, a popcorn bowl, a steamer meal bowl, a Carl Vogt trigger, a homemade light /sound flash trigger, PVC pipe and a power pack.
Apr 27, 2010. 3:50 AMrfowler643 says:
I power it by batteries but I also have a plug in to run it off a plug in power pack as well.
Thanks for your idea.
Apr 9, 2010. 5:28 AMrfowler643 says:
What an absolutely outstanding project.  I especially like the peanut butter jar slave flash.  I completed one last night and am working on a second one now.  It is very convenient to position these flash units wherever I need additional light.
I had to experiment with an old Canon speedlight on my XSi to get the right flash sequencing to overcome a premature firing of the flash jar. It would be nice to control the timing to make it easier to use with the camera factory flash but I am very happy with it.
The trigger circuit using the calculator photocell is brilliant!  So cheap and works so well. Thanks again for the projects.  They are great!
I am going to make a flash unit and house it in a plastic steamer meal dish that is made of milky white plastic. This container should act as a nice light diffuser when combined with the disposable flash units.
Thanks again.
Apr 20, 2010. 3:58 AMrfowler643 says:
I was able to use the flash jar with the camera in manual and the speedlite set to ASA25 f2.8.
I completed a 4 flash unit I will be using for a studio flash.  I combined all the triggers to a common connection but the flash trigger I used does not trigger all the flash units.  If I manually short the trigger wire, all four flashes fire.
I am going to try adding one or more Carl Vogt triggers to see if that helps.  I can add a picture or two as soon as I tidy up the finished product.
Thanks again for the amazing project.
Apr 11, 2010. 6:53 AMrfowler643 says:
I am using a Canon EOS XSi DSLR.  The speedlite I use is is connected to the XS1 hot shoe and is an old speedlite from my 35 mm Canon SLR.  I was able to use the flash jar with the camera in manual and the speedlite set to ASA25 f2.8.  Otherwise it seems the flash jar doesn't like to syc with the camera even when using the speedlite.
I need to play around with the camera, the speedlite and the flash jar more.  I made a second jar now.  I have the orientation of the flash to the photocell set up in such a way that one jar is for right hand flash and the other is left hand flash.
Apr 10, 2010. 3:35 AMrfowler643 says:
This is a great project.  I also noticed there was a posting for a peanut butter jar slave flash.  Is this by the same author?I made two of the jar flashes and am very pleased with the performance and portability.  Thanks to that inventor as well.
Jun 30, 2009. 6:30 PMguydie5 says:
i asked for some used cameras at cvs and they refused me
Oct 27, 2009. 11:14 PMpeterrabid9 says:
Try Walgreens, or wait until someone else is behind the counter :-D  Seriously, when I worked at Walmart, we would supposedly get $.50 for ever camera we sent in.  That added up to alot at the end of film's popularity, but after that, kinda iffy.  Worse case, pick up some cheap junk cameras at the Dollar General, and use them up for fun.
Aug 3, 2009. 9:48 PMpancho del rancho says:
SLAP JUMP GET THEM SLAP THEM AND RUN FOO
Feb 24, 2009. 5:47 PMTheBestJohn says:
All I could find at my components store was a 0.10 uF 400V cap (They never have what I need)... will that do?
Feb 25, 2009. 9:20 PMTheBestJohn says:
bah... neither way worked... guess I'm going to have to hunt down a proper cap... I used metal polyester... could that be it... is it supposed to be ceramic?
Nov 20, 2008. 12:02 AMuMicro says:
Divet, Can you use a contact relay to trigger of the unit? is there a timing issue with the relays?.. i have also seen to build a Safety flash unit which (quote): The voltage is limited to safe levels and the SCR fires the flash. The circuit is effectively a switch in series. I'm building a much bigger version with 16 flash heads, and a variable capacitor that doesn't rely on any slave units.. I have currently completed one prototype that works with a simple switch that triggers 4 units and currently trying to implement the relay system but i don't know if there is a timing issue. Can you get back to me on of a relay can work or not..
Jun 17, 2008. 6:30 AMDerin says:
you could also use 380V mains for the photoflash
Jun 21, 2008. 4:53 AMDerin says:
photoflash bulb , that is
Sep 25, 2008. 4:52 AMLinuxH4x0r says:
would it work on only 120 or on 240?
Sep 25, 2008. 11:09 AMDerin says:
380V three phase delta config. aka phase to phase, 120 or 240 wont cut it and you need a brief voltage of about 1kv on the trigger plate for the bulb to do its thing
Sep 25, 2008. 5:28 PMLinuxH4x0r says:
darn. I didn't think so
Nov 19, 2008. 11:47 PMuMicro says:
The flash work on 1.5 volts, the heads are small so they don't require high voltage. if you want to use 3 phase power, you have to pull the board completely.. and design another.. Phase power is more for the xenon flash bulbs, cause its more efficient. The problem here is the current supplied. that's why the power box is in parallel instead of series. To boost the amps.
Oct 23, 2008. 1:34 PMoptix says:
I would recommend using a resistor to discharge the capacitor. It's much safer than the screwdriver method, even though it's not as fast. My favorite method is a 40W 120V light bulb, with a 10 Ohm 10 Watt wound capacitor in parallel, all attached via test-leads. Then you can visually see how close to drained the capacitor has become, before touching it. I've used this method on many capacitors, some very large (think mega Farad).
Nov 19, 2008. 11:44 PMuMicro says:
discharging a small capacitor is quite safe.. if as you said discharging a much larger capacitor is much safer.. for this project just be sure to keep eyes away from the spark.. most of the time if the flash doesn't fire the arc won't be that big.
Aug 28, 2008. 8:10 PMarphoto says:
what type of capacitor is that?
Jun 24, 2008. 10:17 PMpeterrabid9 says:
Hey, what happens if you put the batteries in line? Does providing more voltage give a faster recycle time, or does it fry something in the circuits? Still a good Instructable, I'm going to build some things using this puppy.
Apr 21, 2008. 8:41 PMblodefood says:
Disposable? Why not recyclable?
Jun 21, 2008. 4:57 AMDerin says:
it is recyclable it says disposable because it is used till the storage is full then it gets recycled after retrieving images at a photo shop
Mar 10, 2008. 11:24 PMezfoxz says:
We did this and dared my friend tommy to piss on the board. The result was bad he was rolling on the ground screaming in pain pissed all over his self. Me and my friend Tod laughed our asses off. Well until he got up. Tommy was realy pissed off and came after us with a 2x4 he was trying to kill us over this what the hell. luckily I was faster than my other friend Todd. I triped him and thats the last I seen of them Im hoppeing we can just put this behind us and be friends agin.
Apr 1, 2008. 9:15 AMDerin says:
wat is a 2x4
Apr 3, 2008. 1:37 AMEstwald says:
A piece of wood 2 inches tall by 4 inches wide. Standard lengths are 6 feet, 8 feet and 12 feet. Also note, the 2 by 4 inches is rough size, planing and finishing reduces the final dimension.
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:Divet
