Step 7AA Battery Pack
iImage Information
Rewire the AA battery pack so the batteries are in parallel, not in series. This will keep the voltage the same (1.5 volts) but increase the amps. Use a needle nose pliers, screw driver and a soldering gun to remove metal contact plates (spring and nipples). Cut the plates with tin snips and place all the springs on one side of the battery pack, and all the nipples on the other. Take a bare wire and solder all the nipple plates together. Then solder all the spring plates together with another wire. Attach the red wire to a nibble plate and the black wire to the switch. The switch in turn connects to a spring plate. Install batteries and test the voltage with a multimeter.
Drill a hole through the lid side of the battery pack and bolt it to one side of the cookie tin. Run the battery wires through another hole into the cookie tin.
