3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Disposable Fountain Pen Refills
Being too cheap for a real fountain pen, but prefering the feel, I ended up with a number of these cheap disposable versions that I found at various places. Problem is that with the amount of writing I do these things last about two days. Therefore I needed to find a way to refill these things cheaply.
For this project you will need a number of items.
Flame Source
Paperclip
Empty Fountain Pen
Pliers
Fine Grain Sandpaper
Rubbing Alcohol
Vine Charcoal (charcoal without binder works best)
Aluminum Foil
Tape
Glue Gun
Optional:
Small Drill Bit
Funnel
Jar of Ink (only if you don't want to make your own)
Update:
Make sure that you seal the pen very well with the glue. This pen later exploded in my pocket.
Step 1Opening the Pen
Opening the Pen
In this step we will be opening up the back of the pen so that we can empty and clean it out. The first thing to do is to pull off this dinky little end cap. A pair of pliers here work well, but make sure that you don't squeeze too hard. While you can still block off the pen, it's easiest to use the cap that's included.
48 comments
1-40 of 48next »
Oct 15, 2011. 12:07 AMkctess5 says:
I'm all for being frugal and all, but really, if you had saved the amount you spent on just those three in the picture (and I can guess you've had more than that over the years) you wouldn't be that far off from a Noodler's pen ($14) or a Lamy Safari ($25ish) which are both easily refillable, and the feel of it will be much nicer
Sep 22, 2011. 2:10 PMALogan97 says:
Would powdered graphite work instead of charcoal?
May 6, 2008. 1:39 AMWurdBendur says:
Note that the ink you produce this way will be somewhat acidic, and you won't want to use it on anything that needs to last a long time. In a few years you'll start to get a halo around your writing, and eventually it will eat all the way through the paper. I guess by that time you won't be worried about it.
Oct 16, 2010. 1:53 PMkudzookrazy says:
I am afraid you got it backwards. Charcoal is ALKALINE, not acidic. It will be acid-free, and this is probably why old charcoal drawings do not brown, with the iron oxides, unless the paper has acid in it. Now it may be too alkaline, absorb water, and thus rot the paper. But it is not due to the acidity of charcoal.
http://gardening.about.com/od/soil/f/Wood_Ash.htm
Jan 22, 2011. 7:39 PMWurdBendur says:
You are correct. Charcoal is in fact alkaline. In either case, one should be aware that this is not an archival ink.
Oct 16, 2010. 1:55 PMkudzookrazy says:
I would recommend a filtration at this funnel step. To use a fine cotton, would take out any missed chunks of carbon.
Apr 10, 2010. 3:17 PMkleewm says:
instead of pulling out the nib/section assembly and risk destroying the seal, here's a method i used.
It involves using a syringe to create a vacuum in the pen so that it sucks ink into the reservoir.
http://www.youtube.com/watch?v=SEdJyrSEsMc
thx for the description on how to make the ink. i didn't think it was possible for the fine charcoal bits to make it through the fibre feed.  :)
Apr 20, 2010. 9:01 AMkanzume says:
Thanks for the handy tip! This is not messy at all!!
Apr 20, 2010. 12:47 PMkleewm says:
u're most welcome :)
the same technique can be used to refill any disposable pen that makes use of liquid ink. i've tried it with Pilot Hitech point and a couple of other brands that has a finned section. The ink I used is Parker Quink.  I've not gotten around to making ink myself.
Jun 24, 2007. 7:41 PMs.armorsmith says:
Where can you get disposable fountain pens
Aug 12, 2009. 10:00 PMMikeHungerford says:
Google is your friend. :-) Search for "Pilot Varsity" or "Pilot Vpen" and you'll find plenty of on-line sources. Staples and Office Depot used to carry them, but they no longer have them in their stores, at least where I am.
Jun 3, 2008. 10:03 PMgangstabrutha says:
I found some the pens in this Instructable at Office Depot.
May 6, 2008. 1:34 AMWurdBendur says:
When I refilled mine, I just pulled the nib out of the front. It came right out with the help of some pliers and went back in easily enough. Though admittedly it's a little loose now.
Aug 12, 2009. 9:58 PMMikeHungerford says:
I did one of mine the same way. Worked fine and doesn't leak as I was warned it might.
Jun 3, 2008. 10:48 PMgangstabrutha says:
is a disposable Varsity pen flexible enough to write calligraphy like Copperplate? Cuz im just starting calligraphy and want a cheap pen to start off with
Aug 12, 2009. 9:57 PMMikeHungerford says:
Simply stated, no. For copperplate-type calligraphy you need a flexible nib and holder; fountain pen nibs of that type are expensive and hard to come by.
Jul 3, 2008. 12:51 AMWurdBendur says:
You might be able to manage Copperplate, but I don't really have the experience with it to know if it'll be very good. I can say that you can get pretty good control of the thicks and thins if you're careful. But these pens do not have flat nibs, so I don't recommend them for most other styles.
Jun 26, 2009. 3:47 PMcurryhackett says:
.....or you could just get a REAL fountain pen and buy the cartridges. $4 for like 5....hardly worth all this trouble. lol But varsity's are nice....
Jul 19, 2009. 3:25 AMmephistocat says:
Or an actual fountain pen as opposed to a cartridge pen. -laughs- Then you'd only need to draw the ink up into the fountain! Agreed about the Varsity's, though. X3
May 4, 2009. 6:12 PMfallenspirit123 says:
are the pilot varsity pens any good ? im thinking of getting a couple to try out the fountain pens and if Me likey ill get a dragons descendant(hopefully)
Jul 3, 2009. 11:24 PMNitidus says:
I like them. They are slightly less picky about pen angle than Shaffer calligraphy pens and require less pressure to lay the ink.
Jul 8, 2009. 7:18 AMfallenspirit123 says:
ok thats good :)
Mar 24, 2009. 11:11 PMamh210 says:
Ground Charcoal Ink will clog the pen feed and the nib slit. Fountain pen inks are made with dyes, not suspended "grit."
Dec 6, 2008. 5:42 AMpineapplenewton says:
ha step 4 you spelled fountain wrong.
Nov 4, 2008. 6:41 PMnc527 says:
GUYS! I figured out a awesome way to refill thease. so the first pen a bought was a catrridge pen that to wide a nib so i took it back but i forgot to grab the second catr that came with it, so when i opened my varsity i figured just flush the pen and then puch a hole in the end of the sheaffer skrip cartridge and insert the open end in the back of the varsity and then puch in the end thats facing u thus allowing the ink to come out. Now do not over fill the varsity as it only will hold bout 1/2 a cart. after u put the ink in, quickly cap the pen and just use glue or just tape it up and lay it flap with the cap on for atleast a day befor using it as if using it right away it will drop ink everywhere. but last night i did this to mine and using it right away ink dropped like a thunderstorm and rain when i used it. so i capped it and sat it on my dresser.well bout 10 min ago i got it and guess waht--no more splatter.Ive wrote bout a page of writing annd no drops or anything.
Jun 4, 2008. 11:05 PMsuepark214 says:
The Pilot Varsity pen is a very nice pen. But I always found the nib to be little too thick. Thankfully, JetPens came out with the new fine point version (V fountain pen http://www.jetpens.com/index.php/cPath/214_492). If you like thin nibs, I would suggest trying it out. Of course, these are still not refillable. But when I'm looking for cheap refillable fountain pens, I like the Pilot Petit1 pens.
Aug 29, 2007. 2:29 PMkludge000 says:
You might try using the syringe from an ink refill kit for pc printer to put the ink in the pen. Also the Japaneses make a very nice art ink that comes in little blocks, and is made from soot.
May 31, 2008. 1:00 AMgangstabrutha says:
Isn't it the Chinese that make the ink blocks from soot?
May 31, 2008. 8:08 AMkludge000 says:
-ink stick info: In the Orient, ink is found in the traditional form of a solid stick. Liquid ink is made by rubbing the ink stick against the wet surface of a particular type of stone. Ink sticks are made by burning either vegetable oils (such as sesame oil, rapeseed oil, and paulownia oil), or pine wood and pine resin and collecting the soot, or lampblack, which is then combined with animal hide or bone glue, spices, and minerals. The mixture is compressed and dried into a stick.
May 31, 2008. 10:26 AMgangstabrutha says:
So is it the Japanese or the Chinese that invented ink sticks?....o_O
Jan 25, 2008. 2:25 PMshadesofsisyphus says:
You could always get a cheap fountain pen with a refill converter. I have a Lamy Safari Fountain pen with a converter. Total 29 dollars. For 12 dollars (I think it was less, but for the sake of argument...) I bought a bottle of Noodlers ink (Yes, I know, the name is funny. It actually has a catfish on it) that will likely last me the next 3 years. The pen will last forever unless I break it. So, for no effort and an average of 14 dollars a year I have a wonderful pen. That cost drops once you figure that the pen will last for decades hopefully.
Jan 17, 2008. 4:28 PMhedgiehog says:
mine has these cool catriges, you pop one it and go, they last a month and i got a few hundred, theyre cool
Feb 6, 2007. 5:36 PMokto says:
To add to what middawn said, you probably don't want to use India or other pigment-based ink, as it tends to clog up the nib. if you've ever seen a crusted-up old fountain pen at an antique store, you know what I'm talking about.
Also, a syringe is the absolute tool for re-inking a disposable (or really any other kind) of pen. Control, precision, and minimal mess potential. A 5-10cc syringe is just the right size for the quantities of ink you'll be dealing with.
Try to get a 14ga or bigger needle if you have a Luer or Luer-lock-equipped syringe and grind/sand the end dull so you don't accidentally give yourself a nice big inkjection.
If you can't get an actual hypodermic syringe, try to get one of the ones with the built-in pointy plastic nozzle like they give you after you get your wisdom teeth taken out.
Syringes can be ordered online (as long as you are 18 or older) from Andro USA Inc.
Lastly, no, I am not a junkie, my mom is a nurse.
Oct 1, 2007. 9:38 AMsmokehill says:
Yes, standard syringes should make the whole operation very simple. I used to have a really nice-writing cheapie Shaeffer pen with the little plastic refills, which are outrageously expensive compared to the price of bottled ink. Since I wrote all day in my job, it was also a real pain to go out buying those little refill packs all the time. So I talked my dentist out of a used syringe, washed it out, and kept refilling my empty tubes. You can seal the little hole with a spot of glue, but since the pen sat on my desk all day I usually just refilled the same "refill" every few days. Eventually, the hole may get too large from wear, but it never actually happened. This was 20-odd years ago, but if I remember the math correctly, those refills cost me about 15 or 18 cents apiece, but I could refill around a hundred of them from a bottle of ink that was about a buck-and-a-half. Syringes without needles are available readily online, and since most people know at least one diabetic, it shouldn't be hard to get one if you explain the purpose. Now that I'm on insulin, I throw away two syringes a day .... Syringes are also useful for dispensing tiny amounts of light (sewing-machine-type) oil in tight places. And don't forget to rinse out the syringes immediately after using the ink -- or anything else -- or they'll clog. Just suck up some water and squirt it out a few times until it looks clear.
Apr 4, 2007. 5:58 PMsk8er6 says:
say man. good work on the tut. Honestly, I only opened this for the homemade ink, and I would like to know how water proof your ink is. And as jtobako said, if it isnt, is there some kind of bonder, but more specifically, what is a bonder?
Aug 20, 2007. 10:23 PMkillerjackalope says:
cornflower starch in very small amounts could help or PVA glue (untested) cornflower starch works ok in my experience of this (all to do with a lucky pen) but only a small amount can be added as it could cause clumping if there's any more than necessary
Aug 20, 2007. 10:20 PMkillerjackalope says:
actually my dad and I found the easiest way to refill any pen that uses thin ink... fountain, rollerball etc is to go to a shop with rubber stamps etc (craft shop) and get the bottle refills for stamp inkpads take the syringe from your inkjet refill kit you undoubtedly have lying about (everyone has at least one somewhere) pierce the ink cartridge with the syringe and fill or if possible pull the nib out and fill with ink. A bit of sellotape covers the hole nicely.
Aug 15, 2007. 4:37 PMcraftykitty says:
You can also grab the nib below where it flanges with needlenose pliers (wrap with a rag to keep the finish smooth) and firmly pull the nib straight out of the pen (this can be messy.) Refill with an eyedropperfull of ink, and shove the nib back in as far as it will go. It seats firmly and does not leak. Anyone else agree that the McCormick disposable pepper/spice grinders are tops, and has worried off the grinder mechanism with a screwdriver to refill it with peppercorns?
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kearney
