3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Disposable camera coilgun
A tutorial explaining how to build your own coilgun from some disposable camera's flash circuits.
It doesn't require much money (if any), but you need some basic soldering skills and electronics knowledge to finish it successfully...
If you have any questions don't hesitate to ask me!
Step 1Getting the parts
Getting the parts
What do you need
- About 5 disposable cameras (used) with flash circuit (you can probably get them for free at your local photo-store if you ask nice)
- A soldering iron
- Some wire
- A plastic ballpoint-pen, ink tube removed so you only keep the hard outer plastic tube
- A light-switch
- Electrical insulation tape
- Plenty of enameled magnet wire (ca. 0,5mm diameter)
- Some soldering skills and some electronic knowledge
461 comments
1-40 of 461next »
Mar 4, 2012. 1:13 AMPSYCHOMADD says:
Where can i buy some soldering skills and electronic knowlege.
Dec 3, 2006. 9:03 PMelectronicfreak22 says:
When you say attach them in parallel,(I'm not very good with electronics)does that mean attach the (-) sign to the (-) sign on the other capacitor? Thanks
Feb 25, 2012. 4:10 PMsverige says:
If you need high current, you would wire them in parallel, positive to positive.
If you need high voltage, you will need to wire them in series, positve to negative
Jun 11, 2009. 9:15 AMalvin9861 says:
I'm using an old paintball gun for kicking the round stock to the coil. I took out the guns barrel and made a new barrel with my coil on it . I use an auto ignition coil for my power source w/out caps. It does very well w/out the caps and can fire rapidly w/out constant charging.
Dec 2, 2011. 12:27 PMpositr_n says:
what do you use to power the ignition coil?
Aug 16, 2011. 1:50 PMjbussé says:
+32 number that ought to be BELGIUM !! hallo mede bewoner van het regeringsloze land :D
Nov 17, 2011. 11:54 AMdiy_bloke says:
Hoe lang nog, gewaardeerde zuiderburen?
Nov 22, 2011. 1:45 AMdiy_bloke says:
Di Rupo ook niet meer :-)
Jul 14, 2011. 7:51 PMElectronics Man says:
Do the capacitors have to have the same rating if I wire them in parallel? I have 2 80uf, and 4 160uf but they have different voltage ratings. Can I use all of them together?
Aug 21, 2011. 4:29 PMLeelaKrishna says:
yes
Aug 19, 2011. 6:05 PMArticas says:
do i have to leave the flash bulb in the camera circut
no you have to take it out
Jun 7, 2011. 6:04 PMR.A.T.M says:
how do i know wich way it fires
Jul 1, 2011. 6:44 AMfirefletcher says:
Aim it at your face and fire it. You'll soon find out.
Mar 4, 2009. 4:25 PMcherwa says:
do you have to put the capacitors in order from biggest to smallest? or can they be the same size?
Jun 9, 2010. 4:01 PMpenguin27388 says:
no, it dosn't matter in parralell the capaciter volts/uf are added together
Jun 28, 2011. 9:01 PMvbexpressrocker says:
No, in parallel the capacitance of the capacitors are added, not the voltage.
In series, the capacitors voltages are added together, and the capacitance is taken away from each other.
May 28, 2010. 1:45 PMleven says:
If you need to ask that, you should not try this.. the 300 volts cap would have no trouble killing you.. so read up a bit on basic electronics and you will now the answer, and how not to kill yourself.
Aug 21, 2011. 4:31 PMLeelaKrishna says:
I tazed my self atleast 300 times with just one capacitor of 330v and hey i'm still here It just hurts like hell for about 2 mins
Oct 22, 2010. 8:10 PMbadideasrus says:
i care to disagree. 300 volts means crap if the amperage is super low.... like a flash camera's cap is. besides, volts don't kill, amps do.
Jun 19, 2011. 6:51 PMusb key says:
A diagram would have been nice
Jun 8, 2011. 6:12 PMR.A.T.M says:
pleas help if i have the coil coring the hole pen but 1 1/2 inch n the front
May 10, 2011. 7:43 PMfsilva-1 says:
The battery is not charging the circuit. I have tried everything but it is useless.
Apr 28, 2011. 2:46 AMpadmanabhapsimha says:
why don't you build a boost converter? it is more efficient than a camera charging circuit. It just requires some basic knowledge of electronics. really effective too. it charged my12000 MFD capacitor to 63 volts in just 20 seconds. yeah it is 12000 micro farads. works better than a 120 to 480 micro farad cap (single 120 or 4*120 in parallel) charged to 400 volts. you can also build a simple power cutoff system so that you need not disconnect the battery from the circuit. you can control this entire system using just two 555 timers. One for the charger and one for the trigger. it will be better if you replace the relay with a solid state switch like an SCR, triac or a thyristor. mine is capable of switching 800 volts , 260 amps of current. There is also no danger of any welding of contacts. It also reduces the power loss by 30 to 40 percent
May 10, 2011. 6:38 AMxmitman says:
Hi padmanabhapsimha,
What SCR part number did you use?
May 10, 2011. 8:43 AMpadmanabhapsimha says:
my prototype used a TYN616
May 10, 2011. 8:41 AMpadmanabhapsimha says:
i used a 'NTE5519' . You can use any SCR or triac with a surge current rating of 600 amps. you can usually overshoot this rating if your cap discharge time is lower than 16 milliseconds
Mar 14, 2010. 5:47 PMbendog38 says:
 would a .177 caliber pointed airgun pellet work as ammunition
 what about a small plastic airsoft bb           and what is the fps on this thing
Oct 22, 2010. 8:13 PMbadideasrus says:
it would work in a rail gun (the lead pellet), however. but as they said, it has to be magnetizable (for those who don't understand 'ferromagnetic')
Oct 23, 2010. 7:39 PMbendog38 says:
then how do I make a rail gun? seriously, i want to know, i have a science fair at my high school coming soon.
Apr 28, 2011. 2:35 AMpadmanabhapsimha says:
i would advise you not to build a railgun with just basic components for a science fair competition. a coil gun will produce more impressive results and it won't be damaged by wear and tear if you construct it properly
Dec 5, 2010. 10:15 AMbadideasrus says:
sorry for the late reply. a rail gun, in it's most basic form, is just two rails that you pass lots of current through. i made one once from tin foil and a nail. it was a really childish effort, but the nine volt battery was enough to burn holes in the foil, which was neat.
there are several sources for rail guns on the net, do some searching. and above all, be carefull. the bigger the gun you intend to make, the more likely you'll kill your self with electricity.
Apr 24, 2010. 5:02 PMbombmaker2 says:
Neither would work because plastic is nonferrous and airgun pellets are made out of lead, which is also nonferrous. As for fps, I don't have a clue.
Dec 5, 2010. 10:16 AMbadideasrus says:
fps would really matter on how much juice your giving it, right? so theortically, no two shots would ever be the same without some kind of capacitor measuring thingy.......
Dec 5, 2010. 11:06 AMbombmaker2 says:
Pretty much. But I'm not sure how much of a difference there would be.
Apr 6, 2010. 2:36 PMM4A1DrumRoll says:
it has to be metal
Mar 29, 2010. 12:36 PMShambler says:
If it's a plastic pellet, unlikely. Coilguns shoot projectiles with a sudden pulse of electromagnetism, ergo any projectile must be ferromagnetic i.e. made of iron or another material attracted to a magnet.
1-40 of 461next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:AlfonsVH
Full-time student (applied laboratory science) // part-time hardware hacker // part-time all-around great guy
