3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Disposable camera coilgun
Step 2Disassembling the cameras and getting the right parts
- First of all, disassemble your cameras and carefully remove the flash circuits.
- Look for the big capacitor on every circuit board (a cilindrical thing) and touch both connections with a screwdriver. BE CAREFUL! This will probably give a great spark, since the capacitors may still be charged.
- Choose the flash-charger-circuit board you want to use. Mark the location and the polarity of the capacitor on the board, so you know how to connect the string which will be explained in step 5 later. The (-) side is the one with the vertical stripe printed on the cap above it.
- Identify the charging-button and triggering-switch on the circuit board which were originally used to load and trigger the flash, and solder the wires connected to them together, so the switches are both closed.
- Desolder the big capacitors from every circuit board, and throw away the boards you don't need - so not the one you chose earlier.
10 comments
Feb 25, 2010. 10:30 AMderbert says:
DON'T throw away the other boards the other boards, you can use them for tasers, even without the huge caps
Apr 8, 2009. 5:08 AMfrixx says:
I want to know will it work with two 350w capacitators on paralel ? you can send an email or just reply here thanks!
Apr 30, 2009. 1:33 PMbylerfamily says:
Yes it will.
Apr 8, 2009. 5:09 AMfrixx says:
my email is fran.goldner@gmail.com
May 7, 2007. 5:37 PMdumdog927 says:
can you email me what the trigger switch looks like at dumdog@aol.com or send a comment repley
May 22, 2007. 5:32 PMdumdog927 says:
i mean the trigger on the NEW disposible cameras cause i cant find any old disposible cameras with obvious trigers
May 25, 2007. 6:36 AMdumdog927 says:
i think your kodak camera is either and old type or a different type from the one i have it has a push button for the charger
May 25, 2007. 6:30 AMdumdog927 says:
sry my email is dumdog927@aol.com but i took apart a kodak and its circuit bourd looks different its like green and where can you buy a universal circuit bourds? thanks for the help so far (:
Jun 1, 2007. 7:52 PMgirrrrrrr2 says:
what you need to do is connect the two pices of metal sticking out and that will cause it to flash/fire!!!
Feb 13, 2010. 9:46 AMmjohnson22lr says:
What do you mean by connecting them? Solder them, solder another wire to them, etc? BTW, avhproductions.be/ is down, and the closest thing that is still up is some music site.
Mar 7, 2010. 11:00 AMgirrrrrrr2 says:
well those 2 wires that stick out just need to touch or have the current bridge across them... so solder a switch across them or 2 longer wires.. just make sure it isnt always bridged.
May 7, 2007. 5:35 PMdumdog927 says:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:AlfonsVH
Full-time student (applied laboratory science) // part-time hardware hacker // part-time all-around great guy
