Step 4Assembling the coilgun
- Wind a coil using the enameled wire and the plastic ballpoint-pen. Do this by turning the wire around the tube. The coil should be about 2,5cm long. Wind several (about 10) layers on top of eachother, but don't forget to insulate each layer with electrical tape.
- Scrape off the coating of the enameled wire at the ends of your coil; enameled wire-coating isn't conductive
- Solder one end of the coil to one connection where the flash-tube was before. Solder the light-switch to the other end of the coil, and the other end of the light-switch to the other flash-tube-connection.
what should i do... should i decrease the number of capacitors, increase the voltage or change the coil. if the coil is the problem what size would you recommend?
I am only a novice (if that) to electronics so I have only little knowledge on how well this would work.
problem number 1 is you have the capacitor discharging into the coil, and according to ohm's law, current is directly proportional to voltage for a given resistance. The instantaneous current from that 330V cap can easily be hundreds of amps, and I have yet to see a *common* transistor survive that rush of power when you flip that discharge switch (in my experiences they'll likely fail in the most explosive way possible). Hook up a transistor you don't mind killing in place of the coil and you'll see what I mean.
Problem 2 is the coil is a giant inductor which you're passing very large current and pretty high voltages through. When that field collapses it'll induce *more* current, which has to be anticipated and dealt with, It's the same reason you can't hook a motor directly to an arduino.
I'm not an expert, so some of the details could be off, but in my personal experience, I haven't found a way to use commonly available parts to control a coilgun due to the incredible amount of power they'd be subjected to.
To resolve problem one I would, with my minimal knowledge, try to add a high operating voltage relay switch into the charging/discharge circuit, though if this works it would be hard to implement into an instructables due to the many different commercial circuit designs for flash op boards from cameras.
In regard to No. 2 I have very little knowledge of inductors but could you add another inductor which will take away the problem into a suitable circuit.
These are my novice ideas so can people please correct me and suggest suitable solutions.
yes
i thought electromagnets only had 1 "polarity," so it would attract iron no matter how i wind the coil.
scientists actually have yet to make a magnet with only one pole, so that would be pretty amazeing if you did it with a simple electromagnet.....
like it was said befor tho, wind in the same dirrection. it shouldn't matter which way though.
