loading
Since almost three years now, I've been eating lunch at school using the same disposable fork. This plastic flatware people use like toilet paper is actually quite sustainable when used for a long period of time. While I keep my little polystyrene fork in my school bag, I notice that most students' desks are filled with dirty plastic spoons, plates, coffee cups and more forks. (Design education...)
I had to create a clock for an auction benefiting students in industrial design. I only had to look on five different tables to get what I needed.
Step 1: Stuff
Picture of stuff
YOU WILL NEED :
6 cleaned forks
6 cleaned soup spoons
Polystyrene sheet less than 5 mm of thickness
A clock mechanism
Gorilla or Super glue
Step 2: Clean
Picture of Clean
Once you've collected all the used spoons and forks, use a little bit of water and soap to remove any residue of food. The paint won't last on anything greasy.
Step 3: Core
Picture of core
Trace a circle on the polystyrene sheet and mark its center. Use a pair of compasses or a circular object. Your circle should have a diameter of 12 cm. Then use a cutter, scissors of a band saw to remove the excess plastic.
Step 4: Drill
Picture of Drill
Use a 1/4 drill to make the hole in the center of the circle.
Step 5: Glue
Picture of Glue
Apply super strong glue to the base of the disposable flatware and stick them around the circle. Keep enough space for the mechanism. You will have to stick it too.
Step 6: Dry and paint
Picture of Dry and paint
Once everything is glued, you can start painting the clock. Make sure not to put paint in the battery compartment. You may want to add a little ring or hook on the back of the mechanism to help you hang it on the wall. Now, install the clock's hands, put on a battery and set the time. Project finished.
Step 7: Be funky!
Picture of Be funky!
With these instructions, you have an infinite possibility of designs. Just let your imagination go crazy.
-Samuel Bernier
flying_carrot made it!1 year ago
Everybody wonders where I bought this clock, cause it looks amazing. Thank you for this idea, it was fun making it. :)
agomes63 years ago
http://www.instructables.com/id/Iteration-on-the-Disposable-flatware-clock-by-Samu/
I tried my best to give you the proper credit :)
Loopstyle3 years ago
Like like like :) in this link you can find more colorful ones http://loopstyle.se/2012/03/10-different-d-i-y-cutlery-upcycles/
thks
paqrat3 years ago
You might want to use different colored hands for ease in use. Maybe white.
paqrat3 years ago
Great look. I had an idea some while back to do this with regular flatware. Yours is probably more easily doable and possibly better looking.
Brilliant idea, and it looks SO contemporary and stylish! I love it!
handy1573 years ago
To make the '12:00' position stand out, you could use a knife for that position.
chicopluma3 years ago
Really cool
jwatson-13 years ago
EXCELLENT! Crafty! Simple, plain and neat to use the Shakers' terms!
nanaverm3 years ago
And it's so lightweight!
shazni3 years ago
I did this when i went through my clock phase ( i go through craft phases :-))
only it was metallic silver. great job!
nike053 years ago
Nice one
tukas3 years ago
I like it! Great idea!
