Disposable Camera Nixie Tube Driver
 by the_don125
Featured
Before I get too far in this instructable, I would like to say that this was not my original idea. You can see two implementations of this idea already on Flickr. The links are:
http://www.flickr.com/photos/mdweezer/322631504/in/set-72157594420700670/
http://www.flickr.com/photos/samwibatt/1610784412/
On with the instructable! This documents how to turn a regular disposable camera into a high voltage power supply capable of driving 2 or 3 medium-sized nixie tubes, for roughly $8.
***Disclaimers***
This instructable works with voltages in excess of 250V. This is more than enough to give you a potentially fatal electric shock if handled incorrectly. If you are unfamiliar with how to work with high voltage, please refrain from performing this instructable. Exercise caution throughout the following steps to avoid electrical dangers. If you choose to undertake this instructable, you do so at your own risk.
This instructable involves soldering. A soldering iron becomes very hot during its use, to the point where it can cause instant second-degree burns. Exercise caution throughout the following steps to avoid burns. If you choose to undertake this instructable, you do so at your own risk.
Step 1: Gather Materials and Tools
For this instructable, you will need:
A disposable camera
A potentiometer of 100Kohms or higher
A resistor of 50Kohms or higher
Wire cutters
A small screwdriver (may not be needed, depends on your camera)
A multimeter
A soldering iron
Solder
Red wire
Black wire
dumle29 says: Jan 13, 2011. 2:26 PM
ive accedentialy shorted one of those caps with my finger.
i guess as long as its on the same hand, theres no worry (not across the heart) but it HURTS LIKE HELL
furrysalamander in reply to dumle29Mar 14, 2013. 10:57 AM
I was burned by a transformer from a scanner fluorescent lightbulb. Luckily it was just across my finger. Hooked up to a computer power supply, ouch... I had charred spots on my finger.
BrunoG in reply to dumle29Jul 8, 2011. 8:59 PM
I only got shocked by a small transformer, nothing big, it was the transformer that comes with the "Radioshack Learning Lab" kit.
techno guy in reply to BrunoGOct 4, 2011. 8:33 PM
Hey! I have that kit. It's pretty useful. I'm still learning from it. I also made a shocking circuit from it and you could adjust how much the shock hurt. I don't think that kit is still being sold, is it?
the_don125 (author) in reply to dumle29Jan 13, 2011. 3:06 PM
Its true, if you only work with one hand, and zap yourself only through that one hand, you are less likely to stop your heart via electrocution.
That being said, enough of a zap can create internal burning, putting the victim into shock, so there is always the chance of a fatal shock when working with voltages above 36V (some sources say as low as 12V).
Always remember, electricity is our friend, and just like any friend, you better treat it with respect, or else you will get burned.
eXtremeSomething in reply to the_don125Jul 26, 2011. 1:07 PM
I got a shock of a car battery once, despite my beliefs that there isn't enough potential difference to across our body
the_don125 (author) in reply to eXtremeSomethingJul 26, 2011. 1:10 PM
All depends on the person, some can feel shocks from sources as low as 10V, some don't notice till much higher.
tsagert in reply to the_don125Jun 9, 2011. 9:26 AM
A few people have been killed in my old line of work, 48v DC systems in telecom offices.
I only got ring voltages on my forearm when reaching in to hook up wirewrap connections on the AT&T switch.
You dont always know that cap energy wont go in your finger, up a nerve of vessel and navigate its way to a vital organ and not right out again.
knektek in reply to the_don125Jan 18, 2011. 11:22 AM
I got shocked by an EL wire inverter and it wasnt pretty. It's output was 200 volts ac but it only ran off 2 AA cells. So, i guess it is a matter of current, not volts. My slayer exciter outputs 4000 volts and it burns my finger!
pickford78 in reply to knektekJan 20, 2011. 8:28 PM
Current and voltage play parts in how dangerous it is, but current is the main factor.
dumle29 in reply to pickford78Jan 20, 2011. 10:28 PM
Yes. If you don't have enough voltage, you cant pull the current needed, however high voltage doesn't meen that it will pull a large current. the power supply high not provide enough of a puch.
U=R*I
so if R is high and U is low, I needs to be low or the math wouldn't add up
tsagert in reply to dumle29Jun 9, 2011. 9:31 AM
Pretty much any wall wart can kill you, hence why GFIs trip at about 4 milliamps (but wont work unless current isnt returning, like using two hands to stick two bare wires into the hot & neutral of a GFI, it wont ever trip if Iin=Iout).
Higher voltage makes the current able to travel along or penetrate your skin.
Matrix-technician in reply to tsagertJun 24, 2011. 12:47 PM
While that's true voltage is not what kills you. Tazers operate at 1mill+ volts! It's the amperage that is dangerous.
agm88 says: Nov 26, 2012. 12:57 PM
you could DIE
forte1994 says: Nov 4, 2012. 10:17 PM
Um... its not the voltage that kills its the amps... and realistikly think about it. Can u touch both ends of the 1.5V battery with out dying? V=ir therefore if you increase the voltage u decrease the current thus making it not deadly. HOWEVER THIS DOES NOT APPLY IF U HAVE A PACEMAKER!! That zap can stop it... basicly: Yes use caution when working with electricity No u wont die if you touch the cap. It will hurt a LOT tho. BTW a car battery can kill even if it only has 12V because it can out put MASSIVE amout of current!
the_don125 (author) in reply to forte1994Nov 4, 2012. 10:43 PM
What you said does not make sense. "V=ir therefore if you increase the voltage u decrease the current thus making it not deadly." Basic algebra states that increasing V while holding R constant will result in an increasing I.
You are correct, that it is current that kills, not voltage. However, the human body has a skin resistance of approximately 47kOhms, when dry, so you need a reasonably high voltage to generate a dangerous amount of current across the chest. Basic V=IR shows you only need about 1V of potential difference to generate the generally regarded to be "lethal" current of 10uA across the chest, but don't forget the cross-section of the chest is rather large in comparison to the heart, so not all of the current flows through the heart.
Once you exceed about 36V though, that cross section difference is not always enough to prevent a lethal current from flowing through the heart. Some people are more sensitive to it than others (some people can feel a jolt with as little as 10V), sure, but you won't see me grabbing two terminals at a 36V potential difference with opposite arms. Because these capacitors can let out a jolt at upwards of 300V, you see how they can be dangerous; only one pulse of "enough" current is needed to do very weird things to the heart.
This is why when working with high voltage, you want to use only one hand, and pocket the other. This way, current is not inclined to flow through the chest; it will stay in the arm, maybe cause external and/or internal burns, but that's a far better fate than stopping the heart.
It is actually known that a 9V battery can kill; if you manage to pierce the skin with both terminals in such a way that the current chooses to flow through your bloodstream into one arm, across the chest, and out the other, enough current is generated to stop the heart. This is because blood is rather low-resistance, so a high current is generated. Without your skin acting as a safety resistor, even surprisingly low voltages can be very dangerous.
the_don125 (author) in reply to the_don125Nov 4, 2012. 10:59 PM
Also worth noting: the 47kOhms of dry skin resistance generally will completely overwhelm the internal resistance of a battery. That is why you can take (usually) 12V worth of AAA batteries, or a 12V car battery, and touch across the terminals with dry skin, and you won't know the difference; the current that will flow is almost identical, despite the car battery's significantly lower internal resistance.
Assuming a car battery to have an internal resistance of 0.2Ohms, and AAA batteries to have a series resistance of 100Ohms, we get:
12V / (47k + 0.2) = 255uA
12V / (47k + 100) = 254uA
Not much difference!
Of course, with wet skin (or in the case of pierced skin), this story changes dramatically. Let us assume we're talking pierced skin, so only the blood is providing resistance, and let us assume blood provides 10Ohms of resistance:
12V / (10 + 0.2) = 1.17A (yes, Amps...you'd be good and fried)
12V / (10 + 100) = 109mA (still very dangerous)
Our friend the capacitor, as discussed above, has a resistance similar to the car battery, extremely low, and therefore extremely dangerous when at high voltage.
the_don125 (author) in reply to the_don125Nov 4, 2012. 10:47 PM
tl;dr
Current is the killer, but you need sufficient voltage to overcome resistance to cause harm.
Low voltage is dangerous in *some* cases.
High voltage is dangerous in *all* cases.
(The above is only true when working with DC.)
forte1994 in reply to the_don125Nov 5, 2012. 4:32 AM
I see. Well i always thaught that because the power needed came from a 1.5V battery ment that no matter what it should not kill you but Its good to know now that I am wrong as im starting work with el wires. Wouldn't wana make this my last project! Thanks!
resistanceisfutileiflessthan1ohm in reply to forte1994Nov 26, 2012. 10:57 AM
if used (in)correctly energy from a 1.5 volt battery may be able to do some harm, however if you remove the capacitor all you can get is a painful shock, the capacitor on the other hand could probably do quite alot of damage, i have been working on something a bit similar today.
GASSYPOOTS says: Jan 2, 2012. 4:49 PM
dude take the batterys out first >.< derp >.<
the_don125 (author) in reply to GASSYPOOTSJan 2, 2012. 5:47 PM
You can take the battery out (there is only one), but the capacitor will remain charged. Only taking the battery out and failing to discharge the capacitor is a great way to get yourself electrocuted.
WV_Kokamo_Joe in reply to the_don125Apr 15, 2012. 6:13 PM
You are exactly right! Except I was trying to repair a digital camera and one of the caps lit me up! I didn't know that cameras had components that required such high voltages and amps.
It is much worse than grabbing AC wires! Always discharge any cap before working on any circuit. I do now!
mr monoply33 says: Dec 7, 2011. 8:55 PM
This just saved me A LOT of time! Thanks!
(When I was younger, I was messing with one of these boards. I knew better than to touch the large menacing cap, what I didn't think about was avoiding the solder points it of which it was attached to other parts of the board. Lesson learned.)
FallenSub says: Sep 16, 2011. 5:59 PM
I always thought that these circuits provide around 300 volts. How did you get it to be around 180? Voltage divider? If so, can I use 1/4 watt resistors?
I presume you shorted your multimeter with connecting it directly to the output? I didn't know these can provide currents over 200mA (these usually have fuses rated at 200mA).
Other than that, it's a nice instructable you've got there!
the_don125 (author) in reply to FallenSubSep 16, 2011. 6:18 PM
Yes, I had a 200k ohm potentiometer in series with the nixie, so the nixie would drop 180V, and the pot would drop the rest. It seems these circuits have a fairly high internal resistance, so they cannot output very much current. In fact, if we take a look at step 4, we can somewhat figure out the internal resistance!
If we assume that the circuit will output 300V open-circuit, and by putting a 50k ohm load across the voltage source, the output then sags to 230V, you should be able to use ohm's law to figure out the internal resistance. (230V / 50k = current; 70V / current = internal resistance). Obviously this is flawed because we don't know if the open-circuit voltage is 300V, but its the best I've got for now.
As for my meter, I did connect it across the output with a fully-charged capacitor in place. While the circuit itself can probably only supply 10mA or so short-circuit, the capacitor can dump a fair amount of current, which it did.
FallenSub in reply to the_don125Sep 17, 2011. 4:31 AM
Thanks for a fast response!
I did exactly the same thing a couple years ago. Fuse in the meter blew so hard that I could see a huge spark flash through the nontransparent meter casing! But fuses are quite cheap, so thats not a problem.
Also, do you think a 1/4 watt resistor can do? Im not sure, coz, lets say the current is 10mA, voltage drop on a resistor 120V, so that's 1.2W.
Or am I wrong here?
the_don125 (author) in reply to FallenSubSep 17, 2011. 7:00 AM
Depends on what you're trying to power. If you're going to max out the supply, then in theory, yes, a 2W resistor is needed (though I feel like the camera might burn out first). If you're just trying to light a nixie or two, I've only needed to pass about 2mA, which is 230V (voltage source after adding safety resistors) - 180V (nixie tube voltage) = 50V * 2mA = .1W, so well within the abilities of a 1/4W resistor.
FallenSub in reply to the_don125Sep 17, 2011. 8:03 AM
Okay, thanks for your time!
Halt! I am Reptar says: Feb 20, 2011. 5:19 PM
Does the charge button need to be shorted?
the_don125 (author) in reply to Halt! I am ReptarSep 16, 2011. 6:44 PM
This camera actually had an on-off switch for the flash, rather than the more common "button" design. I didn't have to short anything, but rather used the on-off switch as a power switch for this power supply. I liked having that feature rather than having an "always on" supply that would've resulted from shorting the charge button.
Halt! I am Reptar in reply to Halt! I am ReptarMar 2, 2011. 8:26 PM
I had to solder the charge button closed to get my Nixie to light up, i dont think you mentioned that. Maybe yours doesnt use a charge button? I got some modern Kodak ones from Walgreens' recycle box.
sci4me says: Oct 19, 2009. 3:04 PM
So I can just discharge the cap and then cut it off as long as the wires are connected to the circuit?
the_don125 (author) in reply to sci4meOct 19, 2009. 3:15 PM
Sure, that is probably a much safer way to use this circuit.
DrWilliamHorriblePhD in reply to the_don125Jul 28, 2011. 5:06 PM
I've heard rumor that replacing the cap with a diode is a preferred solution, but I don't actually know why, nor what orientation to place the diode in. Thoughts?
the_don125 (author) in reply to DrWilliamHorriblePhDSep 16, 2011. 6:30 PM
You would want a diode rated for 200V reverse breakdown voltage, connected "backward" so that it would not normally conduct.
Why?
Well, the diode would prevent current from flowing as the circuit powers up. However, nixie tubes like to be driven around 180V, more than that and you might put too much power through them, shortening their lifespan. The diode will start conducting backward when the circuit is at 200V, ensuring the circuit stays at or below 200V. This does improve safety somewhat as well.
Now, with this circuit's approximate internal resistance of 15k, that means the internal resistance must dissipate 100V (the diode drops the other 200), for about 6mA of current. This results in the diode dissipating 200V * 6mA ~ 1.3 W of power, so get yourself a diode rated for 2 or more Watts of power dissipation, and you'll be set!
grstearns in reply to the_don125Oct 31, 2009. 3:34 PM
Wouldn't holding the shutter button down for a few seconds be enough to discharge the cap so that it would be safer to open?
the_don125 (author) in reply to grstearnsSep 16, 2011. 6:33 PM
Not always. The gas discharge tubes that make up a camera flash work on the same principle as the nixies in that they will operate down to a certain voltage, then stop conducting. The point where they stop conducting will often leave a fairly high voltage still in the capacitor.
sci4me in reply to the_don125Oct 20, 2009. 4:38 PM
Alright, i'll try it sometime.
Wally_Z says: Aug 19, 2011. 11:12 PM
What was the uF (capacity) of the capacitor. I want to know so I can crunch some numbers and figure this out.
the_don125 (author) in reply to Wally_ZSep 16, 2011. 6:22 PM
Well, I no longer remember where I put this circuit, so I don't really know. Going by the pictures, I'd say this is a 330V, 80uF capacitor.
vishalapr says: Jun 13, 2011. 9:25 AM
This is a fantastic ible rated 4.5* Maybe you would like to have a look at my ibles as well
krylonultraflat says: Dec 12, 2008. 9:26 AM
how long did the battery last? and have you given any thought into how to power this system from a wall wart?
the_don125 (author) in reply to krylonultraflatDec 12, 2008. 10:14 AM
I believe the original battery that came with the camera lasted about 12 hours. Not the most impressive battery life, but its also only $8. I think I once measured the efficiency to be 70%, though don't hold me to that. As for wall wart power, you'd have to find some way to get the voltage down to 1.5V. Since this is a pretty simple power supply, the voltage of the battery is proportional to the output voltage, so feeding the camera 5V directly could very well turn into about 700V (untested, so it might not). I suppose you could get a 5V wall wart, then run the power through a few diodes, taking advantage of their forward voltage drop to get the voltage down to what it needs to be. I think when running an IN-12A tube at its rated current of 2mA, the current draw on the battery was about 350mA, so that also needs to be considered when choosing a wall wart, as well as if you are going to try to use two or more nixies off of one camera, since those would increase the current as well.
merseyless in reply to the_don125Dec 15, 2008. 1:09 AM
and then you could just go and get an adapter for the proper voltage of the Nixie and be done with it.
tsagert in reply to merseylessJun 9, 2011. 9:20 AM
Going to step-up 120v to 250-300v, huh? I doubt you can find one of those real cheap, if you could at all. I think you miss the ENTIRE point of the instructable.
J-Ri in reply to merseylessMay 29, 2011. 10:51 PM
Yeah, but the instructable for that would be so much less cool than this one! :)
krylonultraflat in reply to the_don125Dec 12, 2008. 1:45 PM
12 hours isn't bad. Thanks for the info!
Halt! I am Reptar says: Feb 18, 2011. 9:14 PM
I plan on eventually powering the Nixies with a wall adapter... Is the capacitor necessary at all, or can i just remove it? What's the use in keeping it?
the_don125 (author) in reply to Halt! I am ReptarFeb 18, 2011. 9:16 PM
The capacitor is completely unnecessary for the circuit's operation, you can remove it if you would like to.
Halt! I am Reptar in reply to the_don125Feb 19, 2011. 12:10 AM
Okay, cool thanks for the quick reply... Just out of curiosity, why would one want to keep the capacitor?
the_don125 (author) in reply to Halt! I am ReptarFeb 19, 2011. 12:12 AM
It serves no functional purpose.
However, I was curious what nixies looked like as the voltage dropped from "operating" to somewhere below their illumination threshold, and the capacitor let me watch that. :)
pmally says: Jan 29, 2011. 3:38 PM
ah who needs safety? its just a nice little shock
robot797 says: Nov 25, 2010. 5:48 AM
it works witout resistors to power a em84 tube
and a small amplyfier
the_don125 (author) in reply to robot797Nov 25, 2010. 8:46 AM
Yes, removing the resistors would actually make this circuit more powerful and more efficient. I only added them as a safety measure, so that I could walk away from the power supply, and return to one that is completely safe, or prevent random passers-by from shocking themselves.
Removing the capacitor would also work, then the resistors wouldn't be needed (I think that's mentioned somewhere in the instructable)
seltzer10 says: Nov 24, 2010. 6:46 PM
ive taken apart literally hundereds of disposable cameras in my time, most have a 330v 100uf capacitor and i have shocked myself a couple of times ofening up cases. it will BURN TWO HOLES INTO YOUR SKIN at the contact points. guys use an old screwdriver to discharge the cap. once this happens to you a couple of times you will never let it happen again. i love disposable cameras. oh and the best parts FREE CAPACITORS and FREE AA's
have fun ,Manditory maddness :x
iflyrc says: Jun 18, 2010. 12:26 PM
I was going to use the disposable camera hack to power a xenon bulb, but it seems I might've fried something in the circuit (transistor?) when i shorted the capacitor. has anybody else had this problem?
junits15 in reply to iflyrcNov 24, 2010. 3:15 PM
you may have given it too much power and burnt out a component
awsomehighvoltage says: Jun 6, 2009. 4:59 PM
you can get free disposible cameras 4 free if u ask them, i got like 10 for free (w/ out film)
NetReaper says: Feb 4, 2009. 1:47 PM
if I were to put a resister between the battery and one of the holder's leads could I turn it into a 90 vdc power supply for a neon tube? It uses .2 ma to be specific
the_don125 (author) in reply to NetReaperFeb 4, 2009. 3:17 PM
Definitely, I was able to get 6ma at 170V from this circuit, what you want should be entirely possible.
NetReaper in reply to the_don125Feb 4, 2009. 5:18 PM
do you know what resister would lower the ma by enough?
the_don125 (author) in reply to NetReaperFeb 4, 2009. 5:57 PM
By my math, you would need a 1Mohm resistor to get .2mA at 90V with a fully charged battery. I'd personally use a 1Mohm potentiometer though, because as the battery weakens, the voltage drops substantially.
goeon says: Dec 15, 2008. 11:38 AM
i added your instructable to the disposible camera guide http://www.instructables.com/id/Disposable_Cameras/
junits15 says: Dec 12, 2008. 4:59 PM
so we are taking the power that would normaly go to the capicitor to power the nixie, right?
the_don125 (author) in reply to junits15Dec 12, 2008. 5:10 PM
Effectively, yes.
omnibot in reply to the_don125Dec 13, 2008. 4:20 AM
Then this could be a neater solution Coilgun
Cool instructable.
LinuxH4x0r says: Dec 12, 2008. 7:51 PM
Nixie tubes are awesome!
mothflavour2 says: Dec 11, 2008. 5:00 PM
wow, so much for building a custom power supply. This is what I'm using from now on.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
