Step 2Disassemble Camera
Also, this step is probably one of the more dangerous steps, because you do not know if the capacitor is charged currently. Do not touch the capacitor or the flash circuit at this point, it may still have energy stored that could electrocute you. Being electrocuted is a bad thing.
Once you expose the capacitor, I highly recommend discharging it. This can be done by touching both wires coming out of the bottom of the capacitor with a screwdriver or other metal object. Make sure the object you use to discharge with has an insulated handle, and only use one hand to minimize risk of electricity flowing across your chest. I also recommend wearing safety goggles, because if the capacitor is charged, sparks will fly, and you don't want one of those sparks in your eye. (sparks can also known as superheated airborne metal fragments)
i guess as long as its on the same hand, theres no worry (not across the heart) but it HURTS LIKE HELL
That being said, enough of a zap can create internal burning, putting the victim into shock, so there is always the chance of a fatal shock when working with voltages above 36V (some sources say as low as 12V).
Always remember, electricity is our friend, and just like any friend, you better treat it with respect, or else you will get burned.
I only got ring voltages on my forearm when reaching in to hook up wirewrap connections on the AT&T switch.
You dont always know that cap energy wont go in your finger, up a nerve of vessel and navigate its way to a vital organ and not right out again.
U=R*I
so if R is high and U is low, I needs to be low or the math wouldn't add up
Higher voltage makes the current able to travel along or penetrate your skin.
