Distance Measurement Using Ultra-sonic and Arduino
Published
Introduction: Distance Measurement Using Ultra-sonic and Arduino
This project is based on RADAR system .but it can detect less distance than RADAR (only few meters).
It uses simple component like arduino nano and ultrasonic
Step 1: Component Required
Ultrasonic sensor(SR-HC 05)
Lcd 16*2
Arduino nano + cable
Printed circuit board(PCB)
Solder and jumper wire
Voltage regulator(7805)
10k potentiometer
capacitor
Bread-board +jumper wires(for Prototype)
Step 2: Hardware Setup
The hardware connection
Step 3: Software Setup
The arduino software should be installed on your computer.But arduino nano drivers are not installed during the setup installation .So you require to download additional drivers based on chip used in nano
#include <Liquidcrystal.h> //lcd library
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //connection of lcd
void setup()
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.print("Distance Measurement");
lcd.setCursor(1,1);
lcd.print("Instructables!!");
delay(4000); //delay for four seconds
pinMode(6,OUTPUT); //echo pin
pinMode(7,INPUT); //trigger pin
Serial.begin(9600); //Baud rate
void loop()
long a;
long b;
float c;
lcd.clear();
lcd.setCursor(2,0);
lcd.print("Distance is");
digitalWrite(6,LOW);
delayMicroseconds(2);
digitalWrite(6,HIGH);
delayMicroseconds(10);
a=pulseIn(7,HIGH);
b=a/2;
c=b/29.1;
lcd.setCursor(3,1);
Serial.println(c); //display distance on serial monitor
lcd.print(c);
lcd.print(" cm"); //in centi-meters
delay(800);
you can download code here
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    Thanks for sharing :)
