3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Distortion For Cheap!
Step 3What You Need
What You Need
Parts list (for my method):
-Two 9-Volt batteries
-Four 100 ohm resistors
-One LM741 op amp
-One 1K ohm resistor (1000 ohm)
-One .1 uF capacitor (any type)
-Two 4.7K ohm resistors (4700 ohm)
-Two 1N914 switching diodes
-One red LED
-A project case
-Two mono 1/4" (6.3mm) female jacks
-One DPDT switch (two way 6 pin)
-One on/off switch
-Perf board (with copper rings on bottom)
-Thin wire
-Soldering iron
-Solder
-Two 9 volt battery holders (just take the tops off of two dead 9 volt batteries, the batteries will fit into them perfectly)
I also suggest getting a solder sucker and some soldering braid. Very useful stuff!
All of the above can be purchased at Radio Shack, so no need to hunt around. The total price should be around $10, unless you need a soldering iron. Those usually run about $10-$20.
8 comments
Sep 16, 2010. 5:49 PMstuntdude47 says:
Where did you get your case? And please could you tell me what a One DPDT switch (two way 6 pin) means. I'm new to this
Sep 27, 2010. 5:01 AMstuntdude47 says:
Thank you. This is very helpful.
Mar 29, 2010. 9:27 AMcaseyC088 says:
what voltage for the   .1 uF capacitor
is 63v okay?
Aug 13, 2009. 12:18 AMepehnclark says:
What are the wattage on the resistors?
Jan 25, 2010. 10:23 AMJodex says:
Pretty much any wattage should work. We're not talking that big powers there that you should worry about the wattage..
Jan 9, 2010. 5:24 AMandy70707 says:
Im guessing just standard 1/4 watt metal film resistors
Jun 23, 2009. 11:49 AMchirp-o-tron says:
I think that that's usually what op stands for in that context.
Mar 23, 2009. 4:50 PMRasengan says:
I went on the radio shack website and found an LM714CN Amp, does the cn matter, and by op do you mean operational?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:heyzuphowsitgoin
