The stutter effect isn't to everybody's taste, so I added a toggle switch to switch it out of the circuit. A bit of advice - the NE555 timer generates a fair bit of noise and pops on the power supply, so I wired the switch to also remove power from the NE555.
Here's a demonstration video that shows the kind of sound you can get with this:
Remove these ads by
Signing UpStep 1Parts list
(1x) Die-cast aluminium enclosure - I used the Hammond 29830PSLA
(3x) Potentiometer control knobs
(1x) Heavy-duty latching DPDT push switch
(2x) DPDT miniature toggle switches
(1x) 2.1mm DC power socket (Use a plastic body one if you are using a metal enclosure!)
(2x) 1/4" jack sockets
(1x) 5mm LED bezel
(1x) Battery snap
(1x) PP3 9V battery
(1x) Piece of stripboard
(2x) 8 pin DIL sockets
Various lengths of stranded-core wire
(1x) 10K potentiometer
(2x) 100K potentiometers
(1x) 470R resistor
(1x) 1K resistor
(3x) 10uF electrolytic capacitors
(1x) 220uF electrolytic capacitor
(1x) 0.1uF (100nF) polyester or ceramic capacitor
(1x) 5mm LED of your favourite colour
(1x) NE555 timer IC
(1x) LM386 audio amplifier IC
if this capacitor is between the signal and the ground then it will change the tone of the output
the tone control on a guitar varies the capacitance between the output signal and the ground
you would need to make the capacitor (and resistors if necessary) the very last thing that the signal passed through before the output
I've made some little mods on Harrymatic's schematic in order to explain clearly what I mean about the distortion's capacitor selector and the switch between the battery snap and DC Jack.
Hope it could help those who don't understand.
Sorry about the picture's quality, I don't know why, I cant upload it in large size.
If anyone have an idea.
If you cant read it send me a message I'll give the file by mail.
I add a little mode, a switch to change the distortion's cap value, a 10nF gives a deep sound who's realy cool with stutter effect, but in distortion, if you reduce gain it produce very strange stuffs.
Thank's for this Instructable. I love DIY guitar effects.
I'll post pictures when I found it.
Sorry about mistakes I'm frenchy, don't hesitate to correct me, I'm always learning.
Would you mind posting a picture of inside?
Where i looked it was about £35
