The stutter effect isn't to everybody's taste, so I added a toggle switch to switch it out of the circuit. A bit of advice - the NE555 timer generates a fair bit of noise and pops on the power supply, so I wired the switch to also remove power from the NE555.
Here's a demonstration video that shows the kind of sound you can get with this:
Remove these ads by
Signing UpStep 1: Parts list
(1x) Die-cast aluminium enclosure - I used the Hammond 29830PSLA
(3x) Potentiometer control knobs
(1x) Heavy-duty latching DPDT push switch
(2x) DPDT miniature toggle switches
(1x) 2.1mm DC power socket (Use a plastic body one if you are using a metal enclosure!)
(2x) 1/4" jack sockets
(1x) 5mm LED bezel
(1x) Battery snap
(1x) PP3 9V battery
(1x) Piece of stripboard
(2x) 8 pin DIL sockets
Various lengths of stranded-core wire
(1x) 10K potentiometer
(2x) 100K potentiometers
(1x) 470R resistor
(1x) 1K resistor
(3x) 10uF electrolytic capacitors
(1x) 220uF electrolytic capacitor
(1x) 0.1uF (100nF) polyester or ceramic capacitor
(1x) 5mm LED of your favourite colour
(1x) NE555 timer IC
(1x) LM386 audio amplifier IC
Visit Our Store »
Go Pro Today »
I would have never thought of these two chips put together.
Oh and one more thing I noticed, when I turn the volume on my guitar down to about 50% the guitar doesn't send a signal to the amp anymore, but the noise and ticking of the pedal does get through. I'm not sure if anyone else noticed that or if it's just me.
Thanks!
I'm afraid I can't answer your question about the guitar volume, as I did all of my main testing using a synthesizer as an audio source - I've only seen this used with a guitar once but I did not hear any problems.
How do you recommend reducing this?
Am I missing something here? Also, I'm having a little trouble understanding how to connect the jacks. Do you connect the pins with the pedal effect, and the grounds to each other?
Besides the jack part, the guide was very clear, so thank you for that! I just lack some soldering skills.
This is how to wire the jacks :
Unfortunately, without the distortion to mask the noise, the clicks and pops from the signal being turned on and off are more noticeable, but if you are running your own distortion through this effect it may not be a problem.
on the stripboard, with the blue lines are they soldered from point to point say with a wire, or is it soldered the whole way across to join the strips?
Sorry I hope that makes sense.
I add a little mode, a switch to change the distortion's cap value, a 10nF gives a deep sound who's realy cool with stutter effect, but in distortion, if you reduce gain it produce very strange stuffs.
Thank's for this Instructable. I love DIY guitar effects.
I'll post pictures when I found it.
Sorry about mistakes I'm frenchy, don't hesitate to correct me, I'm always learning.
