Introduction: Distressed Motorcycle Headlight
About: Making and sharing are my two biggest passions! In total I've published hundreds of tutorials about everything from microcontrollers to knitting. I'm a New York City motorcyclist and unrepentant dog mom. My wo…
Here's a quick technique for distressing/aging a motorcycle headlight to better match your rat rod. My boyfriend's 1971 Yamaha XS650 bobber just didn't look right with the copper finish of its new headlight.
You will need:
  • headlight
  • painter's tape/masking tape
  • utility knife
  • sandpaper, about 800 grit will do
  • rubbing alcohol
  • towel or paper towel
  • gloves, eye protection, respirator and respirator recommended
  • protected, well ventilated area for painting
  • matte black spray paint
To keep up with what I'm working on, follow me on YouTube, Instagram, Twitter, Pinterest, and subscribe to my newsletter.
Step 1: Tape It
Tape off any areas you don't want to get paint on, like the lens, brights indicator, wires, etc. Use a utility blade to carefully cut around the edges of these areas, and press the tape down into any crevices.
Step 2: Sand It
Lightly sand the entire surface of the headlight can, rim, and mounting hardware. Fold the sandpaper and use the crease to get into nooks and crannies that will later catch the paint. After sanding, wipe the headlight with rubbing alcohol and a clean cloth to remove any debris in preparation of painting.
Step 3: Paint & Wipe It
Apply a thin coat of matte black spray paint to the headlight over a protected surface, then quickly wipe the paint away with a towel. Paint will settle in the crevices and on the sanded surface, leaving a dirty-looking, older appearance. Repeat until the desired effect is achieved. Then remove the tape!
Step 4: Install It!
All that remains is to install the headlight on your bike. Soldering is so fun! Thanks for following along, and I look forward to your feedback and bike stories in the comments!
Check out more of my motorcycle projects:
