In the last week in Dundee I managed to get round to doing something that has been plaguing me for about two years: a cribbage board from my friend Suzy. I had already drilled the holes and it took me a while to think up something to laser engrave. I eventually decided on a kind of \'field of shapes\' thing given that the board was already punctuated by hundreds of circular holes.
It would have been much easier to engrave first, then drill but hey, sometimes things don\'t happen in the right order! I have put up the .svg for the layout however so that others can do it in the right order.
There is significance in the name of this cribbage board, but it might take you a while to realise..
The typeface I used is Cooper Black.
Remove these ads by
Signing UpStep 1Get wood, engrave and cut
* Engrave the attached .svg into it.
* Drill the holes marked in red on the .svg (you could engrave these to a shallower depth to help identify them). Drill to half the depth of the material. I'm pretty sure I used a 2.5mm bit..
* Cut the wood on a bandsaw around the outline and sand to finish.
cribbage engraving flat.svg(834x250) 52 KB| « Previous Step | Download PDFView All Steps | Next Step » |
comment
Add Comment
Add Comment
