3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Diversion Safe / Can Safe
  • last photo ←
Here's how to make a diversion safe to store/hide small valuables or cash.
This version has a screw-off bottom, so that the whole thing can be picked up without falling apart and plaster makes it of comparable weight to its original contents to fool those that pick it up.
Step 1What you'll need
What you\
Epoxy (preferably quick-setting)
Plaster of Paris
Soup can or other type of can
Small(er) plastic jar with threaded lid (with label removed for mildew resistance)
Side-cutting Can Opener (did I mention it HAS to be a side-cutting type?)
Several hundred dollars in cash
Hungarian Vizsla (optional)
57 comments
1-40 of 57next »
Mar 3, 2010. 3:16 PMBeszels Magyarul says:
Nice dog, tell it I said "csa" he will know what it means.
Feb 3, 2010. 6:53 PMgma24 says:
 If I left mine in the cupboard, either I or someone else in the house would inadvertently donate it with other canned goods when there is a food drive.
I'll probably remove the food label, cover the can with card stock and put a label on it that says 'ribbon' or something like that.  I'll keep it in my craft room.
Jan 9, 2007. 10:00 AMDanny says:
only problem is if you have something like car keys or coins then they rattle
Feb 3, 2010. 6:46 PMgma24 says:
Fill it with Great Stuff spray foam.  That will buffer a lot of the noise too.
It will expand past the top of the can, but can easily be cut down to size with a serrated edged knife.
Jan 17, 2007. 7:33 PMsumlunatik says:
you could coat the inside with the Plasti-kote stuff, that should deaden the sound. Nice instructable. Thanks
Jan 31, 2010. 5:33 PMtubbychick3n says:
Great instructable. I plan on doing this, and i might try to make a small business out of it. I will probably be using soda/energy drink cans and cooking sprays or whipped cream, etc. Does anyone know where I can purchase empty jars (plastic or glass), that will work for soda cans, in a decent quantity? Maybe somewhere between 7-10 dollars for 10-12 jars?
Jan 31, 2010. 5:40 PMtubbychick3n says:
would these work? (right size and whatnot?)
Jun 30, 2009. 12:05 PMheathbar64 says:
nice Job!, but probably my wife would get it out and cut the top out the first time she got hungry. and then be mad at me because she was all set for soup. I think maybe I'll make one out of an oil bottle or something that goes in the garage. it would be safer all around.
Mar 1, 2009. 2:13 PMDurkaDurka says:
AAHAHAHAHA When i was looking at the step on picture..... it took me like 5 min to realize that your dog was there.... hahha Cool instructable though
Nov 27, 2008. 9:15 PMshadow12952 says:
but what if i got hungry and wanted a can of turkey pot pie?
Jun 13, 2008. 7:56 PMGrey_Wolfe says:
Perhaps a thick Layer of epoxy in the can to Hold the jar, let set then fill in the sides with distilled water (or isopropyl, to prevent nastiness), then put another ring of epoxy around the tope of jar to seal (below the threads. Leave a bit of air between epoxy and liquid. When all set, this would creat the weight, while also sounding like the can has goods in it when shaken. Just an idea.
May 22, 2008. 12:26 AMJames Haskin says:
I made one a few minutes ago... so cool. I used a big Chef Boyardee can and a glass peanut butter jar.
Jan 13, 2008. 4:31 PMrjohnsonspam says:
Great step-by-step guide! Thanks -- can't wait to try it. This should be a lot more fun and less expensive than paying $25 to buy one on-line!
Jan 11, 2008. 5:08 PMjpmartineau says:
Well done! The design is simple, yet elegant. I like the idea of using Plaster of Paris.
Aug 7, 2007. 5:47 PMpoolman says:
Do you have to use epoxy if not what other types of adhesives could you use?
Jul 28, 2007. 8:12 AMdaPerik says:
Just wondrin', could u ask the Viszla something about the sharpness of the edge of the can? And if u can, could u please ask him?
May 28, 2007. 9:25 PMYerboogieman says:
can i use a plastic pepsi bottle?
Apr 7, 2007. 9:21 PMjaytotharrr says:
cool thanks great instructable
Apr 5, 2007. 10:38 PMjaytotharrr says:
how do u think a soda can would work
Apr 5, 2007. 10:33 PMjaytotharrr says:
could i use glue instead of plaster
Mar 28, 2007. 8:14 PMHOMEPIE64 says:
this is pretty awesome cost effect and smart pretty good you get a 5!!!
Mar 8, 2007. 12:12 AMplace name here- says:
I have discovered that most "I don't know about all "can openers can cut side ways. :O but I don't know how smooth the edges are compared to Safety Cut.
Feb 22, 2007. 2:08 PMLaxLovaLV says:
HA HA I love Geocaching! Lots here in Washington!
Feb 12, 2007. 3:00 PMlemonie says:
Make sure you put it in the cupboard with all the other tins. Just like an artificial stone (concealing spare house keys) this will arouse suspicion if you leave it in the wrong place. Fairly obvious, but often overlooked...
Feb 11, 2007. 9:36 PMthemanjam says:
were can i get a can opener at that dont leave marks on can rim?
Jan 25, 2007. 2:21 PMCalltaker says:
THis is a great instructable. One word of warning though. If you plan to use this for hiding a stash of illegal Pharmaceuticals, it will not prevent a K9 unit from finding it. I made one and used my training materials to test it out with both my German Shepard and Golden Retriever (both trained for scent tracking) and they both nailed i right off the bat. I used 8 differnt cans, 1 of which was the safe and handled all of them prior to letting the dogs go. This post is not to condone use of illegal substances, merely to provide a little advice to anyone who may consider this. Also, I dropped a few 'treats' in the safe and the Chihuahua and Poodle nailed it right away too. Gorgeous Viszla. Pure breeds are great, but i love the mutts too. ~C
Jan 17, 2007. 10:51 PMclipper says:
Thats a beautiful vizsla you have there
Jan 24, 2007. 10:05 PMclipper says:
hahaha, i know what you mean
Jan 13, 2007. 7:46 AMsmithw6079 says:
Word must be getting around. I've worked in a state prison for the last 12 years and a new policy restricts employees from bringing in cans, including sodas. My Chicken-Noodle was confiscated last week. : (
Jan 10, 2007. 12:01 PMjjsonp says:
very nice! i will probably use silicone caulk rather than plaster-of-paris though...no mixing, and i feel like it will make the unit a bit more fireproof and soundproof.
Jan 11, 2007. 9:23 AMjjsonp says:
still haven't tried it, but in my experience with silicone it is very firm when it dries, esp. a large mass of it. it's fairly cheap when you buy the big (standard caulk-tube) size too. i'll probably goop it around the sides of the jar too for extra gripping force, but it is a pretty strong glue. maybe this weekend i'll be able to pick up one of those side-openers.
Jan 9, 2007. 8:28 PMcrapflinger says:
what if you don't have a vizsla? can you still make such an effective safe? i've jut got mutts...will that make my safe lower in quality? (i feel that it might...darned pure breeds...always making can safes better and what not :( ) good instructable!
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bighead3
