Diy Air Conditoner With Adjustable Air. Warm and Cool Air
1,562
34
Published
Introduction: Diy Air Conditoner With Adjustable Air. Warm and Cool Air
About: I love writing, I make video in MY UPLOADED VIDEOS channel in Youtube for my instruction, and i love making something. www.instagram.com/balsuryana
Introductions:
Summer is coming and the temperature will rise. Because the temperature is hot, i will show you to make a air Conditioner from trash!. This is different from another DIY's Because i will make it from a old hairdryer fan, not use computer fan. Its more cool and more powerful!
Its easy to make!
Features:
  • Easy to use
  • Use AC supply or DC supply
  • Can choose Cool or Warm air
  • Mini and light
  • Under 20 w consumsion
  • Can work with battery
  • And many more
OK LETS MAKE IT!!
Step 1: Tools You Will Need:
  • Cutter
  • Screwdriver
  • Soldering iron
  • Electrical tape
  • Wire cutter / Pliers
  • Scissors
Step 2: Materials You Will Need:
  • Old hair dryers (or anything with motors and propeller)
  • Super glue
  • Transformer, adaptor or any dc power supply
  • 2 bottles
  • Cardboard or anything you want to make the case
  • And some creativity to make it
Step 3: Open the Hairdryer
  • Take the screwdriver, open the hair dryer and take apart the motors.
  • Open the motors holderlike image 6
Step 4: Take the Bottle Lid and Make the New Motor Holder
  • Take one bottle lid
  • Place the motor on middle
  • Make a hole with screwdriver like image 3
  • And cut triangle with cutter like image 4
  • and attach the motor to the new holder and reattach the propeller
Step 5: Cut the Bottle Neck
  • Cut the bottle neck with cutter
  • Make two
  • Glue with super glue like image 3 and add some tape to make it stronger
  • Close this with the new motor holder like image 5
Step 6: Next!
  • I made the case like image 1
  • Take the old motor holder and glue it to the case
  • Glue the bottle neck with motor to the case like image 5 & 6
Step 7: Next Again!!
  • Take the back cover of the hair dryer and cut it like image 2
  • And glue it to the case like image 3,4,&5
Step 8: The Electricity
  • Take the plug from the hair dryer
  • Solder the wire to transformer (solder to 0 and 220v) and close it with tape
  • Glue the transformer to the case with super glue.
  • Solder the 12v output to the motor like image 6
Step 9: Test the Transformer and the Motor
Plug in the transformer to electricity and the motors will run.
Step 10: The Warm Air.
  • Take the hot element from the hair dryer and take the thin wire (Nichrome wire)
  • Take 2 screw and tie the nichrome wire to the screw
  • Take the switch from hair dryer
  • Make a simple circuit :
  1. Screw - switch - 6v/9v output
  2. screw - 6v/9v output
  3. Like image 6
  • And instal the switch to the case
Step 11: Electricity Steps Is Finish
This is all of the circuit . Now you need to make the upper case like image 2 and 3. Make a hole in front of the nichrome wire, and if you turn on the switch, the nichrome wire will heat and give you a warm air. But if you turn off the switch, this air conditioner will give you a cool air.
  • You can place it on bedroom, living room or any room you want!.
Step 12: Finish!
If you want to know how it works, watch the video
Thanks for look my works
sorry for my bad english
Please like, vote, subscribe me!
thanks!
Happy making
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    2 Discussions
    I like the idea, simple and effective.
    However having a heating element in a cardboard case is, personally, a huge fire risk. By using a differnt case or hving the element in a fireproof enclosure this will work. Thak you for the 'ibble.
