Diy Easiest Solar Charger (usb)
6,362
31
7
Published
Introduction: Diy Easiest Solar Charger (usb)
About: If you can't make it simple,you don't have right to make it...
its very cheap to make
and thus only a begginer project
Step 1: Why You Need One
it is the only source of power during an
apocalypse
emergency
ZOMBIE ATTACK
or daily life
outdoor recreation trip
and it is a free way to charge any of your usb device
Step 2: What You Need to Make One
solar panel
diode
usb socket
container (optional)
Step 3: Lets Get Em Together
glue the solar panel
and press it firmly
here i used hot glue gun , you can use any other glue also
Step 4: Component Details
circuit components
Step 5: Circuit Diagram
this is so simple
Step 6: JUST FOLLOW THE PHOTOS ONE AFTER ANOTHER
no SOLDERING required
just twist the wires together
and make your connections insulated
Step 7: Congratulations You Made It
Step 8: CHARGING SUCCESSFUL
you can charge any usb device that uses 5v
Step 9: Thanks for Watching
but wait don't forget to check out my other projects
Step 10: More Cool Stuff on YouTube and Instructables
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    7 Discussions
    Can i use 12 v solar panel?
    Can I use 3 volt solar panel
    where did you get the female esb socket with the wires, did you just strip one out of another machine?
    great job, except a really close pic of the wire to panel would be helpful.
    did you not connect to the wire running across the front?
    nice. What are the specs for panel? How much current and wattage? Where did you get it? Thanks
