Diy File Sander Handle
881
Posted in WorkshopRepair
Introduction: Diy File Sander Handle
About: Hi , folks i am Aman and i like to make electronics projects and robots. I also like to make aero models like a plane and quadcopters are one of my favorites .I am a 10th class student and i am very much dev...
Recently i faced a problem while sanding some of my soldering iron tip that it was tough for me to use the file due to improper stability because it does not have handle attached to it ......So i decided to make one
Step 1: Materials!!!!
Before starting i wish to list items required
  • Sanding file (probably most important)
  • A fevicol bottle (anything which is hollow and can be used as a mould {choose something whose neck region is big enough to hold the file} )
  • Hot glue gun
  • Lots of glue sticks
  • Paper cutter and some basic tools
  • Sandpaper
  • Tape
  • Paint
Step 2: Cutting the Bottom of the Bottle.
Take your bottle and cut the bottom of the bottle so that you have now access to the hollow part. (DO NOT CUT THE NECK REGION ).After cutting make sure to clean the bottle ........And choose a base
Step 3: Fill It With Hot Glue......
After the bottom is cut and the file is nicely fit start adding hot glue from the bottom . You can add tape on the neck region so that hot glue do not escape out . After the mould (fevicol bottle) is fully filled add a brown tape at its bottom and keep it straight on a surface .
As we know hot glue is hot is sink that whole thing in cold water so the cooling action will be more fast
Step 4: Remove the Mould
After the hot glue had cooled down its time to remove the mould ...Just take a scissor or a wire cutter to cut a notch and tear the whole mould with the help of that notch.
Step 5: Paint It Up!@!
Finally its time to give it a nice finish .......I love orange so i painted it orange!!
Step 6: And Its Ready!!!!!!!!!!!!!!!!!!
After paint has dried you have successfully made a handle for your file
This was my first instructable so if i did any mistake please let me know in my comments section
catch me on You Tube
https://www.youtube.com/channel/UCy94qlZwIAEYNJZO-...
Facebook
https://www.facebook.com/aman.singhal.7921
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    4 Comments
    excellent example of use of mind
    keep it up Aman
    keep it up Aman
    Awesome fix, I love that you used an old bottle for the mold and then use hotglue to create the handle.
    Hey if you ever create some video tutorials on your youtube channel, we'd also love to see them over here. Plus we run fun contests!
    thank you very much it was first comment on my first instructable in my life .....I am soon going to participate in many contests so please do vote for me..............once again thanks for viewing my instructable
