Video of complete robot driving:
http://www.youtube.com/watch?v=Ieb4zxwHs5k
Items Needed:
1-Rc Car (new or used, choose one that could easily have a Rc servo fitted in the steering system. We got ours from Radio Shack.)
1-Barracuda wifi robot controller (http://www.robotics-redefined.com, use coupon "instructables" to get 10% off) http://www.robotics-redefined.com/index.php?main_page=product_info&cPath=28_30&products_id=62&zenid=c4fd241aa334c50cf189918d38319430
1-Wifi Router ( brand does not matter, we will be using a Linksys)
1-Network Camera (again, any brand will work, we will be using a Linksys)
2-Ethernet Cables
1-5v Regulator for camera (may be different if using a different camera.
2-3 7.2v Rc Batteries (3300mAh or greater recommended)
Misc wire, solder, tape etc.
***NOTE***: As of this writing after testing the wifi robot / spybot, I would encourage the use of a different Network Camera. The Linksys camera worked ok but not great, I have heard good results with the Panasonic line of cameras.
Remove these ads by
Signing UpStep 1Step 1: Hacking The Car
The two red batteries are to power the main motor and the barracuda wifi controller. While the blue 7.2v battery will power the Linksys router, 5v Regulator for the camera, and the steering servo. Three batteries are not needed, but i just find that it makes the wifi robot / spybot more reliable and allows longer run times. If you opt for two batteries the Linksys router can handle 40v, so you will be fine running it straight off of the two packs. The same with the 5v regulator. Te only problem will be the power for the steering servo, so you will either have to add another 5v regulator and run it off of that or just get a higher amperage 5v Regulator and run the servo and the camera off of it. The latter would be easiest.
works for the project
http://www.jbprojects.net/projects/wifirobot/
thank you
and to cyrozap=it is really hard....
am i able to put a usb webcam in anyway cause buying an ip camera is very expensive ?
Is it possible to control the car with a usb device, like a joystick ? I have real life applications for this type of device...!
This is pretty awesome. I've wanted to build my own rover since Spirit and Opportunity came online. Roaming the streets, hopping from unsecured wifi AP to unsecured wifi AP, controlled (or commanded) by me on the laptop at home. hehe
please can you tell me specific detailes to make the regulater board plz
and also need to now where i can buy the ip camera because in my country it's above 1200 dollars
thank for helping
Ry25920
