3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY: How to Build a WiFi Robot Spybot
Step 5Step 5: connect everything to the router!
Configure your router to have the base Ip Address of 192.168.1.1. The stock Ip Address for the barracuda is 192.168.1.10. The IP can be changed to whatever you want it to be with the configuration program that comes with it. Connect the camera and the Barracuda wifi robot controller to the router using the two Ethernet cables. Configure the camera to have an ip that works with that of the router and barracuda.
Step 6: Power up and go!
The barracuda wifi robot controller comes with a sample program and source code to drive the car. Power the car up,connect to your camera in the browser, run the sample program for the barracuda and start driving! The barracuda also supports use of a PS3 controller plugged into your computer to control it.
For more info and to see our wifi robot cruising around, check out our YouTube Channel:
http://www.youtube.com/watch?v=n5W9Bi8Hgwc
6 comments
May 18, 2012. 3:18 AMcmorisco says:
hello to this project using tp-link and must be used to compile OpenWRT SDK
works for the project
http://www.jbprojects.net/projects/wifirobot/
thank you
Feb 24, 2012. 10:41 PMfridodido says:
use your old camera phone and install mobiola . fit it into your rc .......simple
Aug 28, 2011. 1:09 PMzandok71 says:
Can somebody tell where can a buy a wifi robot controler ?
May 23, 2010. 10:31 PMtpo22chris says:
Hello
am i able to put a usb webcam in anyway cause buying an ip camera is very expensive ?
Nov 24, 2009. 5:16 AMthalass says:
Is it possible to control the car with a usb device, like a joystick or steering wheel? Or would that require a different program tailored to that application?
This is pretty awesome. I've wanted to build my own rover since Spirit and Opportunity came online. Roaming the streets, hopping from unsecured wifi AP to unsecured wifi AP, controlled (or commanded) by me on the laptop at home. hehe
Nov 11, 2009. 2:25 PMtichland says:
hello
please can you tell me  specific detailes to make the regulater board plz
and also need to now where i can buy the  ip camera because in my country it's above 1200 dollars
thank for helping
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:AppleGuy
