Diy IR Tester Keychain
1,106
34
6
Published
Introduction: Diy IR Tester Keychain
About: radom diy projects
the simple way to build an ir tester
Step 1: Schematic Diagram
all you need is a led, an ir receiver and a coin battery
the range is only 5-15cm (good to test a remote control)
Step 2: Print the .stl Files
print the .stl files or find a nice box for your project
Step 3: Make the Connections
make the connections and glue the led and the receiver with instant glue
Step 4: End
glue the two printed parts and add a coin battery
i use CR 2025
Thanks..!
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    6 Comments
    thanks!! its the simlest way to test infrared devices (but at small distance)
    Thanks for your replay, please tell my when to bay IR - DIODE
    Here in Croatia have Chipotle, and have IR-diods
    Sorry for my bad English
    Claudio
    you can't find ir diode? did i understood right ??
    Maybe not all the people know that you can use your smartphone to check ir using camera app.
    just point your remote to te camera lens, and press any button; on your camera app you should see violet light coming from the remote.
    yes you are right!!
    but iphone's camera,i think, can't see infrared light
