Introduction: Diy Lab Power Supply
Picture of Diy Lab Power Supply
this is lab bench power supply
i use atx power supply as main componet
Step 1: Component You Need
Picture of Component You Need
  • atx power supply(i use 450w)
  • banana connectors
  • switch
  • leds
  • wires(use thickness as per current requirement)
  • wood
  • and some basic componet
Step 2: Make Wood Box
Picture of Make Wood Box
make wood box and connect screws cable clamp
Step 3: Connect Atx Power Supply
Picture of Connect Atx Power Supply
put atx power supply in wood box and connect wire to screws cable clamp
the wire connect according to pin map
Step 4: Diagram of Power Supply
Picture of Diagram of Power Supply
connect all think together as per diagram
and connect all think together on front panel
Step 5: Make Variable Output
Picture of Make Variable Output
  • now make variable output for variable output i use dc-dc converter with variable voltage and current limit .
  • it can output 1.3v to 27v and 3A max
  • connect all componet as per diagram
dc- dc converterhttps://www.aliexpress.com/item/DC-DC-Step-Up-Down...
Step 6: Done
saadland (author)2018-01-11
why 4 potentiometers instate of 2 ??
EE MAKER LAB (author)saadland2018-01-13
i use 2 pot for voltage and 2 pot for current that give me small change in voltage and current value
EE MAKER LAB (author)saadland2018-01-11
you forgot to add a load resistor for stabilization...
no without load resistor it gives me proper out put but now i connect load resistor for safety
gm280 (author)2017-12-24
Oh yea, those old ATX power supplies had some pretty stout current capabilities. And they would make a really nice shop power supply. Thumbs Up!
DhruvP57 (author)2017-12-24
good project thank u for suggestions
About This Instructable
1,040views
27favorites
License:
Bio: arduino base projects, electronic project and info,
More by EE MAKER LAB:  Line Follower RobotDiy Lab Power SupplyArduino Base Auto Direction Robot
Add instructable to:
