Diy Lightsaber From Scratch
2,039
14
Posted
Introduction: Diy Lightsaber From Scratch
Watched star wars?
Always wanted a lightsaber but never got the required materials,
or just found it too complicated to build one using online instructions
Well no matter what the reason is, as far as you want a lightsaber you can follow the instructions to create a lightsaber from
things you probably have lying around your home!!
The lightsaber actually looks much better but my pictures aren't as good because I used my iPads camera which isn't very good
I will try uploading better photos as soon as possible.
If you like my instructable please vote
Step 1: What You Need
For this project you will need:
A used glowstick
A pen torch
A gas stove/ A lighter
Post its (the bookmarks)
Tissue (the most difficult thing to find, you can order it online)
Chocolates (optional, for extra energy)
Step 2: Removing the Lens
Remove the back cover and push the battery forward, this might break some of the casing but it won't
Be a problem.
Once you've removed the bulb pull out the lens.
Step 3: Shaping
Now push the ends of the glowstick and remove the cap
which contains the inner parts of the glowstick, pour out the liquid.
Once you've done that heat up one end of the glowstick and push in the torch,
This should shape the glowstick tube.
Step 4: Completing
Now push the torch into the shaped end of the tube and a tissue ball into the other.
You're done!!!
But if you still want to take it to the next level and add colours follow the next step.
Step 5: Adding Colour
This is very easy,you just need to stick a post it to the torch
if you want a more intense color add a few layers.
You're done!!!
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
