Diy Modern Bird Table
149
Posted
Introduction: Diy Modern Bird Table
this instructable will teach you how to build a lovely black and wooden and astroturf bird table.
Step 1: Design and Parts
first design your bird table and gather all of the parts that you are going to need.
Step 2: Base
then cut your base at 30cmx30cm.
Step 3: The Holes
measure in on two of the corners 3cm each side and put a dot.
Step 4: Drill the Holes
measure on the side without dots 15cm in to the middle and then 2cm in the middle from that side ad another dot.then drill the holes at 2cm which should just fit the rods.
Step 5: The Legs
now that you have the legs together spray them lightly with some black spray paint.
Step 6: 4 Up Facing Rods
then mesure 4 20cm peices of wood and pray them black.
Step 7: Skrewing Them on the Base Piece
then after spraying them srew 1 of them in each corner.
Step 8: the Roof Holders
then cut the roof holders to 30cm and you need 2 of these but if wanted you could add another two a bit smaller to make some more support but i just went with two.
Step 9: Astroturf
then mesure the astro turf to be 30cm x 30cm and cut it.
Step 10: The Astroturf
then stick or staple the astroturf on to the roof and spray the base of the table black
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
