Diy Powerbank Out of Waste 28000+ Mah
1,528
17
5
Posted in TechnologyScience
Introduction: Diy Powerbank Out of Waste 28000+ Mah
About: If you can't make it simple,you don't have right to make it...
this is a big battery power bank to make a difference
Step 1: Why U Need to Make It
the power banks in the market aren't enough to charge your tablet and smartphone simultaneously multiple times
batteries are lying around in ur house
u want to learn something new by building your own power bank
Step 2: About the Batteries THEY ARE LIKE LEGO BRICKS
these are 18650 batteries different from regular AA batteries in size and capacity
one 18650battery is equal to 9 AA batteries in power
even they are rechargeable
they have the highest power to weight ratio
and even last around 4-5 years or 300 cycles
tesla motors used these type of cells in Thier cars and other projects
i got them from my old powerbank,old laptop batteries and from the junkyard for FREEEEEE
Step 3: What You Need
1.batteries-18650
2.cardboard box
3.powerbank circuit
4.tools
Step 4: Gather All the Stuff
Step 5: Lets Start With the Box
cut out the cardboard and tape it up in the shape of a box
make sure that you have a good quality of cardboard bcoz this will only determine the build quality of our powerbank
Step 6: Tape Up the Batteries
make a rugged and durable tape joint all through
Step 7: Battery Testing Time
make sure that none of the battery is dead
max charge voltage 4.2v
min idle voltage 3.6v
during use min voltage 3.2v
try to recover the dead batteries by giving them a jolt of electricity
if they regain their capacity then we can use them if not then they are of no use here
Step 8: CONNECT THEM IN PARALLEL
i used soldering to connect them that may not be the best way of connecting
but there are several ways that are more healthy for the batteries but difficult for me to do
Step 9: Attach a Connector to the Pack
attach connectors to the power bank circuit and the battery pack
plug them together and you are ready to go
Step 10: Everything Is Done
connect a usb cable to the power bank circuit and plug it into your phone
Step 11: THANKS
so if you like my this project perhaps you may some of my others
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    5 Comments
    What app do you use on your phone to measure the USB current?
    It's extremely dangerous to connect lithium cells in parallel unless you first make sure they all have the same or very very similar voltages. ive had a cell burst that for doing that.
    I get very nervous with Li-Ion batteries in parallel. If they're not perfectly matched, they can start a fire. Li-Ion batteries need to be treated with great respect.
    "try to recover the dead batteries by giving them a jolt of electricity" :o
    Please pay attention to potentially damaged li-po batteries. They can explode and start a fire!
    Have a look at this other instructable for some tip to spot damaged cells
    https://www.instructables.com/id/REUSE-YOUR-OLD-LA...
