Diy Rc Tricyle Aluminum Body
Introduction: Diy Rc Tricyle Aluminum Body
Hey guys! Since  few years ago I have always been creating , designing and building fun things so I decided to build a rc tricycle. The idea I have is to use the most simple ways of allowing things to operate , for example : I didn't want gears or crazy mechanisms. I wanted something that you guys at home can easily reproduce and maybe even better! I used a 11.4v LiPo pack , with a 25A speed controller and a low kv motor so that I could use the torque.
Step 1:
I started off by using CAD ( computer aided design) to create a template . I printed it out in a scale of 1:1 and glued it to pieces of aluminium
Step 2:
I cut out the pieces as well as I could with the equipment I had.
Step 3:
I then TIG ( tungsten inert gas ) welded all the pieces of aluminum together ( this was a hard task for me , I am an amateur welder)
Step 4:
I then took a 16mm x 16mm square bar , cut it to size and glued 50mm lengths of wire in a corner ( this is where the wheels will attach)
Step 5:
Give the Beast a paint job ( in my case - white)
Step 6:
Begin assembly , and see where everything will go so you can start gluing . The motor was connected to the tire with use of a prop holder , it just so happened to be that  a 1/10th scale tire fitted on the shaft.
Step 7:
Time for a test drive =D      Video is on Youtube :
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    May I know what is your Size of the adapter (prop holder),servo,wheel,push rod and stop set collar ?
    love your project. I will be making something silimar soon.
    check out Hobbyking if you need cheap but good rc parts
    Thanks ! :)
    That's awesome , what are you thinking of making?
    Yeah I am aware of HK , they have really good prices , its just a mission to import to SA - but its worth it !
