Diy Soldering Station
8,095
65
13
Posted
Introduction: Diy Soldering Station
I came up with this idea because the soldering stand my iron came with wasnt very sturdy and i have seen cool soldering stations for sale but I thought why not just make one, so I did.
I hope you enjoy
Step 1: What You Need
- A decent sized piece of scrap metal
- A sponge
- Dremmle or rotary tool
optional
- A mini fan- I got this out of a computer power supply
- soldering iron w/ solder
- Hot glue gun
- A battery clip
- An on/off switch
Step 2: Bending and Cutting the Metal
You are going to want to take your piece of scrap metal and bend it to about a 50-60 degrees and cut a circular groove into the edge of the scrap metal
Step 3: Connecting and Soldering the Electronics
Connect the positive terminal of the battery clip to the negative terminal of the fan, then connect the positive terminal of the fan to the negative terminal of the on/off switch, and connect the positive terminal of the switch to the the negative lead or the battery. Now you can make it permanent by soldering all the pieces together
The schematic might give you a visual and help you better understand the circuit
Step 4: Gluing It All Together
Now you can hot glue all the components onto the piece of metal as shown in the picture
With the sponge  you can cut ti down to size so it fits
to make a place for your switch you can use your rotary tool to cut a hole in the metal
The reason I put the fan on this project is to extract the fumes of the solder
Step 5: Finishing Up
Now you can clean up the edges by sanding them down and you can whip away all the excess glue and your finnished
if you liked this project you can checkout some of my other projects
feel free to comment and subscribe to my channel
THANKS!
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    16 Comments
    Cool!
    Good job
    Not bad! I made my first one out of an old amp and some plumber's tape. This doesn't look as getto as mine does!
    good idea to be try
    ok this not a soldering station is soldering base.Soldering station is more complicated (with temperature adjusters). Also its recommended to put the iron on a heatsing post. Without heatsing don't leave it for long time you will loose it!....put anykind of heatsing available (solinoid) for soldering irons. something like that
    I think the fan is nice. anything that keeps the fumes away from you is a good thing... I used to do a lot of soldering where I worked and I had to put a fan lightly blowing on my work to keep the fumes from coming up my nose. :)
    What do you do with the fumes you extract? I never thought of trying to extract soldering iron fumes myself. Mostly because I can't think of much I'd do with iron fumes.
    im extracting the fumes because they are somewhat toxic
    you could add an activated carbon sponge filter
    well if you put a Kleenex over the exhaust of the fan it will catch most of the fumes and you can just dispose of the Kleenex when you are done
    I think upgrading to a section of cut furnace filter might work a bit better. The particles from the fumes are in the 0.1 to 0.5 micron range. A filter with a MERV of 16 or MPR of 1000 should cover that.
    The fumes you get are from burning the rosin core flux, but according to wikipedia "Prolonged exposure to rosin fumes released during soldering can cause occupational asthma (formerly called colophony disease[10] in this context) in sensitive individuals, although it is not known which component of the fumes causes the problem"
    So blowing them away from you is a good thing to do, but a filter might properly trap them.
    http://www.hse.gov.uk/pubns/indg249.pdf <--- health risks due to solder fumes
