3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Diy The Best Sunjar in www.instructables.com :-)
It is very easy and cheap to diy a sunjar !My circuit can test the sunshine and the leds turn on only at night and turn off while the sun rise again:)
Step 1The circuit programme
The units can easilly got by electronic pcb junks!
49 comments
1-40 of 49next »
Dec 27, 2010. 5:01 AMdasimpson1981 says:
your doing it again efan over complacating when this will do the same job
Dec 29, 2010. 10:04 AMdasimpson1981 says:
my panels give out 2.5 to 3 volt at 20ma
what i have just found is 2 in series wont run this circuit with the components i am using diffent pnp transitor and 1k res insted of 5k
but if i get another to cells wire them up in series and parallel so i get 5-6volts but 40ma the unit works correctly
Dec 28, 2010. 5:00 PMdasimpson1981 says:
the silver things between the batterys are neo magnets they are easy for snapping togeather batterys
Dec 28, 2010. 4:59 PMdasimpson1981 says:
just to prove i wasent lieing about the amount of leds i run from this unit the breadboard bit of a mess the part i am using for jt winding is somthing i found in an old pc psu same for the transistors resistors and other bits
the first is the light the camera isent showing how bright it really is
the next is the bread board with the above circuit
and the last one is the unit i found in the psu i use for the jt windings
Dec 28, 2010. 7:01 PMdasimpson1981 says:
it is winter here at the moment so they isent alot of sun.
the batterys are fully charged at moment the unit is at present running the batterys flat.
once they are flat i will take the cover of the panels to find out.
need to get a clock and a realy to make a light sensing circuit so i can tell exactly how many hors they run for
Dec 28, 2010. 7:10 PMdasimpson1981 says:
yeah neo magnets they hold the batterys together.
and dead leds as magnetic posts to connect it to the breadbored
Dec 28, 2010. 7:24 PMdasimpson1981 says:
to improve current erm if you raped a 3rd coil the fewer the winds the more current the more wind they are the higher the voltage but less current
jt are not ment for current step up but voltage step up hence they work well with lighting but thats about it
Dec 28, 2010. 7:22 PMdasimpson1981 says:
less winds on the base and more on collector can get higher voltage.
but wont some really fun facts wind a 3rd coil run that thru a diode to a cap see what you get and watch the running current you will be seprised
Dec 28, 2010. 10:05 AMdasimpson1981 says:
got to tell you tho if you build this unit do not and i mean do not look at the led i am still seeing purple dots
Dec 28, 2010. 8:40 AMdasimpson1981 says:
just been messing with this circuit more and well seems any npn and pnp transistor will work the 5k resistor can be swoped for a pot to allow ajustment for the level of darkness it turns on at
Dec 28, 2010. 5:26 AMdasimpson1981 says:
you know it might be worth compareing them both see which one is more effecient
Dec 28, 2010. 4:00 PMdasimpson1981 says:
yeah it is a little simpler just messing with the jt side seeing how many leds i can get working
Dec 28, 2010. 5:31 PMdasimpson1981 says:
a Zener diode would also stop the over charge
Dec 28, 2010. 7:05 PMdasimpson1981 says:
i myself would find out what the trickle charge limit is and have a wind turbine run at that and maybe solar to charge it faster during the day as long as these dont go above what you use they wont be any problems
Dec 28, 2010. 7:20 PMdasimpson1981 says:
then you have nothing to worry about if the battery is 3.6 volts you need to feed it 5-6volts to charge it you need to work out at what ampage to charge it at and for how long
Dec 28, 2010. 7:37 PMdasimpson1981 says:
if one solar panel is 2.4volt and 65ma
in series that would be 2.8 volt at 65ma
in parallel that would be 2.4 volt but 130ma
but that are when they are running at 100% that ant oftern some days i get 1ma other i get the full 20ma of my panels
Dec 28, 2010. 7:48 PMdasimpson1981 says:
you would need 3 solar cells to charge the 3.6 volt battery tho i work it ut for every 1.2 volt battery you need 1 2 volt cell
Dec 28, 2010. 7:54 PMdasimpson1981 says:
yes but for the length of time you ran it with the jt you could of got way more of a charge into just using the solar panels
basicly it will charge faster from the panel then the jt
Dec 28, 2010. 7:47 PMdasimpson1981 says:
yes you are correct i hit the wrong number
Dec 28, 2010. 7:35 PMdasimpson1981 says:
in series the voltage is higher but ampage (current) is the same
in parallel the voltage is the same but ampage is higher
a 3.6 volt battery needs 5 to 6 volts to fully charge same as a 1.2 to 1.5 volt battery needs 2 to 2.5 volts to charge
Dec 28, 2010. 7:44 PMdasimpson1981 says:
dont forget the diode to stop the battery discharging thru the solar panel
Dec 28, 2010. 7:50 PMdasimpson1981 says:
it will charg but take a very very long time to charge
i have found if you run a dead bettery that wont take a charge on a joule thief it will then after take a charge
Dec 28, 2010. 7:55 PMdasimpson1981 says:
ok you have a battery that reads 0.00 volts or 0.10 volts put that in a wall charger and it will not charge
but charge it with a jt for an hour then put it in the wall charger it will then charge
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:efanfengshun(Wang guiyun)
A science lover
