Diy the Best Sunjar in Www.instructables.com :-)
2,271
Posted in WorkshopEnergy
Introduction: Diy the Best Sunjar in Www.instructables.com :-)
It is very easy and cheap to diy a sunjar !My circuit can test the sunshine and the leds turn on only at night and turn off while the sun rise again:)
Step 1: The Circuit Programme
The units can easilly got by electronic pcb junks!
Step 2: Assembling
Now let us see how to make it by one wire one pin,and one wire one pin :)
Step 3: Just Have Fun From Your Sun Jar!
Collect the sunshine and keep it until night to use.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    49 Comments
    my panels give out 2.5 to 3 volt at 20ma
    what i have just found is 2 in series wont run this circuit with the components i am using diffent pnp transitor and 1k res insted of 5k
    but if i get another to cells wire them up in series and parallel so i get 5-6volts but 40ma the unit works correctly
    you know it might be worth compareing them both see which one is more effecient
    yeah it is a little simpler just messing with the jt side seeing how many leds i can get working
    Yes. very clever design but i still want a simple anti-over-charge circuit.
    a Zener diode would also stop the over charge
    How about this one? but i think it could more simpler.
    i myself would find out what the trickle charge limit is and have a wind turbine run at that and maybe solar to charge it faster during the day as long as these dont go above what you use they wont be any problems
    The li -ion cell it self has a protecting circuit in it.
    then you have nothing to worry about if the battery is 3.6 volts you need to feed it 5-6volts to charge it you need to work out at what ampage to charge it at and for how long
    :)From my observation two solar cell series connection are lower than two solar cell parallel connection then jt to li-ion.
    the solar cell :2*2.4v/65vma
    in series the voltage is higher but ampage (current) is the same
    in parallel the voltage is the same but ampage is higher
    a 3.6 volt battery needs 5 to 6 volts to fully charge same as a 1.2 to 1.5 volt battery needs 2 to 2.5 volts to charge
    From my observation two solar cell series connection to 1.2v battery are still lower than two solar cell parallel connection then jt to li-ion.
    Maybe i should use two solar cell parallel connection to 1.2v battery ,:)
    dont forget the diode to stop the battery discharging thru the solar panel
    Does the high volt but lowe current by jt can improve the charging efficiecy to battery?
    it will charg but take a very very long time to charge
    i have found if you run a dead bettery that wont take a charge on a joule thief it will then after take a charge
    What is it meaning?
    ok you have a battery that reads 0.00 volts or 0.10 volts put that in a wall charger and it will not charge
    but charge it with a jt for an hour then put it in the wall charger it will then charge
