Diy Wind Turbine
3,739
125
Posted in WorkshopEnergy
Introduction: Diy Wind Turbine
About: I love to camp,hunt ,fish,bike,canoe or basically anything to do with the outdoors.
This is my simple diy wind turbine, it is 16ft off the ground, has three foot blades for a total diameter of about 5ft and the generator is a simple permanent magnet motor out of a treadmill. The blades were originally 4ft long for a 7ft diameter and spun in the slightest but they also hit the pole in the slightest breeze and near self destructed :(. So after watching many videos on how to stiffen windmill blades I came across the pallet banding idea, basically all you do is rivet thin strips of steel on to the trailing edge of the blades. I already had steel pallet banding but you can use aluminum flashing from a hardware store. I put my rivets 2in apart for a total of 16 rivets per blade, after I finished they were alot stiffer but not quite stiff enough so I cut them down to 3ft. That sums up the blades so onto the tail, I just hose clamped the generator and an old office chair swivel too one end of a piece of strapping and slotted and slid in the plywood fin on the other end. The office chair swivel fits perfectly into a piece of pipe which fits into the tower. The tower is a 16ft piece of steel pipe concreted into the ground 3ft with no guy wires to mow around. The last thing I did was mount my multimeter to the pole then cut the test leads off and wired the multimeter directly to the output wire from the generator, so I could monitor the output voltage. The kind of pipe I used was 4in pvc sewer pipe cut into thirds rather than quarters for an bigger wind catching surface. Thanks for looking!! Hope this helps you with your wind turbine project!!
Step 1:
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    3 Comments
    I forgot to mention that the reason the multimeter shows a negative reading is simply because I accidentally put one of the connections postive to negative!! :)
