3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Diy Xbox wireless controller adapter for Pc
This instructable will go over the steps to connect a RF module from an RROD xbox to your computer so you can use a wireless controller with your computer. ******DISCLAIMER******* DONT TRY THIS IF YOU DONT HAVE ANY EXPERIENCE WITH ELECTRONICS/SOLDERING OR COMPUTERS IM NOT RESPONSIBLE IF YOU SCREW UP.... now that we've gotten that out of the way
Parts List:
Arduino UNO - a wonderfull microcontroller board you can get it on ebay or at radioshack
RF Module - from a broken xbox/ ebay
Soldering Iron - mine is a cheap radio shack model
Solder - also avalible at a local radio shack
USB cable - scavenged from old electronics (i found it in my parts bin)
2 1N4001 diodes
Wire cutters - for cutting wire....
Wire strippers - for stripping wire...
pliers - for holding small things/ bending wire...
Wire - i have bolth some 22 AWG wire from radioshack and some fancy 30 AWG Kynar wire (easily avalible on ebay) pretty much any wire will work as long as it is small enough to solder to the connectons on the RF shield
Step 1Soldering ....
Soldering ....
First strip the usb cable, inside there will be a black wire, a red wire, a white wire, and a green wire. there will also be some shielding and a shield ground wire (usually not covered) these you can cut back to the plactic. strip about an 1/8th inch of plastic off each of the four wires.
Next you will need to solder the diodes to gether in series ->-> and then solder the side with the line on it to pin 1 and the side without the line to the red wire in the usb cable **** make sure the diodes are the right way around before soldering****
Now you can solder the white wire to pin 2, the green wire to pin 3, and the black wire to pin 4
solder a piece of wire to each of pins 5-7 too, make sure they are long enough to connect to your arduino
5 comments
Apr 21, 2012. 11:32 PMscampbell13 says:
can i use this on a arduino pro mini ............would the pins and programming be the same ?
Jan 18, 2012. 10:36 AMComputothought says:
Frys also sells the arduino board, but it is know as Osepp uno.
Jan 19, 2012. 6:42 AMComputothought says:
Been using Jameco for a long time.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Timinator01
