Step 5BONUS.. videos... Web rebuttals.... improvment ideas
OK first off all i built this knowing of a couple of products already on the market
like this and that was stolen from here i hadn't seen this design but seems to be more of a general separator from what I've read
i didn't have $50-$1200 to spend on something that's easy enough to build from leftovers
the camera has trouble focusing on the small particles flying by so fast but you can clearly see a downward counterclockwise then i tried some toner it adheres to the plex blocking the camera view
in this video you see the cyclonic action is good at the bottom of the chamber and more chaotic at the top the ability of this design and the size wight of the stuff your trying to separate is key to success it works great up to a point heavy objects just drop heavy aerodynamic objects spin around and drop lighter particulates have a 50/50 chance of going out or down (this is where improvement is needed... if you need hepa3 grade separation)
at the beginning of this video we see a chunk of something stuck in the vortex my guess is the cyclone vortex is started by the constant air exchange from the higher volume lower container to the lower volume upper chamber this would also explain the chaotic flow at the top as the effect dissapates up the chamber ..why better designs have a v shaped chamber to pull the effect closer to the intake (how do you do this with pvc ? progressive reducers?) then various toner tests trying to catch the vortex without dirting up the plex
results the smaller the particles (toner is as small as.03 micron) don't collect as well
possible improvements : spiral intake after a cubed chamber ...multiple vorticity chambers
more of a total startover if i wanted to goto a much higher separation but ill see what i can do with what i have available without scrapping what i have
Add Comment
