Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Like any heat exchanger the greater the temperature differential the greater the efficiency.
make pool cooler please.
I am building a dome shaped heater with black flex hose (vacuum line) like in the new leslies flier and will post results.
Plus, after a cold snap or rain, it heats up way faster. The whole point is getting more swimming time than you would get without the heater, and last year was a total success in that regard.
If you built one without the glass, and ran it only at night, it would work as a radiator and cool your pool down.
http://www.builditsolar.com/Experimental/PEXCollector/PEXCollector.htm
This website is a wealth of info for any DIY'er Have fun
The original author states s/he spent $250 in *just* the copper tubing for a 76" x 46" solar heater.
I've seen, on HomeDepot.com, 500 ft of 1/2 tubing (designed for drip-type watering solutions I believe) for between $30 and $35. I used this page: http://deepfriedneon.com/tesla_f_calcspiral.html
to do a rough calculation of how many feet of tubing I would use in a 4x4 box, which is approximately 300 ft of tubing -- well within my 500 ft mentioned above.
I'm still searching for ways to determine how much I might reasonably hope to gain in temperature via 300+ ft of black tubing. I welcome any suggestions or data input here.
As for the instructions, if we do decide to use copper tubing, we're definitely going to be referencing this Instructable! Thanks for sharing!
Anne.
It does look like the flow of water is going to just run through the pipe nearest the inlet, it will always take the path of least resistance. There are 2 things you can do to improve this though, and they are both reasonably easy.
Flow should always be controlled on the outlet, not on the inlet. This has the effect of slowing everything down and not giving the flow an easy route through the pipes. This should help spread the flow over all the pipes.
Turn the panel so that it is vertical, with the valve at the top becoming the outlet and the inlet at the bottom. The valve on the outlet will keep the flow across all the tubes and also thermal convection will help move the water through the outermost pipes. As the water is heated it will rise naturally.
If you go for this please let us all know how you get on.
If you want to work out the volume, first go and look on the manufacturers website, it will likely say so.
if not, measure across your pool in meters(diameter), half of that is your radius. The area of a circle is radius x radius x 3.14. I am guessing that the radius of your pool is about the same as the panel is wide (76" so near as dammit 2 Meters) 2 x 2 x 3.14 = 12.56 Sq M is the area of your pool. For the volume of a cylinder in cubic meters you just multiply the area of the circle by the depth. So I am guessing the pool is about a meter deep? So
12.56 sq Meters x 1 meter = 12.56 cubic meters.
1 cubic meter = 264 gallons
so..
12.56 cubic meters x 264 = 3315 gallons
measure your pool and work it out with your son for the fun of it. or measure it and pass the measurements on, happy to work it out for you
Nice piece of kit already though and any gain is a benefit.
my name is dave, joined today after reading your comments on pool solar. i live in a small town pennington south coast natal south africa. two things i would like to ask. one would ambient temp govern the size of a panel area.
2 working out your btu ratings for area water to be heated, not also depend on ambient temp. eg 20 square meters pool area, ambient temp 15 deg c
20 30 deg c
why i ask is our temp is similar 2 south coast america winter max 19 deg c summer +- 32 deg c would you design be worked on winter conditions.
shot
dave richards.
Copper is a good choice as it does have better thermal conductivity but PVC is a much cheaper choice of materials that will have no chemical reactions to other materials used in the pool or with other metals used like in the pump.
