Introduction: Do You Know How to Send Arduino Sensor Data to Cloud Server(Thing+ Server)
Picture of Do You Know How to Send Arduino Sensor Data to Cloud Server(Thing+ Server)
I know Arduino platform for IoT. So I implemented a firmware of Arduino by Ethernet SW modification because I can handle a source code easily. You can know the status of equipment even if it is so far. Please refer to the following step.
Step 1: Prepare Materials
Picture of Prepare Materials
Please refer to the following.
1. Arduino UNO
2. Ethernet shield
3. Easy Module shield
4. LAN cable
5. USB cable
Step 2: Hardware Connection
Picture of Hardware Connection
Please connect an LAN cable and USB cable
You can get more HW info by the following site.
https://www.arduino.cc/en/Main/ArduinoBoardUno
Step 3: Prepare Development Environment
Step 4: Software
I uploaded Arduino project. You can download this project file. And then import project into Sketch.
After compile, you can send sensor data to Thing+ cloud server.
Step 5: How to Run : Preparation
Picture of How to Run : Preparation
Step 6: How to Run : Modification
Picture of How to Run : Modification
1. To must modify MAC address, apikey, temperatureId in firmware code.
2. To add source codes of DHT11.
3. To verify and upload to target.
Step 7: How to Run : the Result
Picture of How to Run : the Result
1. To check the result of Dashboard through Thing+ Server.
Shan MichaelR (author)2018-01-15
hi can i ask if we can use DS18B20 temp sensor for this just to be sure thanks
About This Instructable
9,255views
14favorites
License:
Bio: S/W Engineer for Open Source Platform.
More by bingdo72:IoT Base Platform With RaspberryPi, WIZ850io : Platform Device DriverIoT Base Platform With RaspberryPi, WIZ850io : Ethernet Module DriverIoT Base Platform With GCC, WIZwiki-W7500 : MQTT
Add instructable to:
