Step 3Glue Clamp, Repeat.
Set the base out on the wax paper and gather the four middle layer squares so that they are within easy reach.
1) Pick the best corner of the base. Mark this corner with pencil so that you can easily find it again. Pick the best corner of the middle layer and point it towards the middle of the base. Add glue to the under side of the middle layer and align it with the corner of the base. Make sure both edges are flush as possible. Clamp the two pieces together. Two or more clamps may be needed. Check to make sure that no glue has seeped out of the crack towards the middle of the base. If so clean it up with your wet towel or wooden splint.
2) Now take the straight edge and align it to one of the sides of the layer you just clamped on. This will assure that the channel resulting from the layers will be aligned. Using the bottom slider layers as spacers glue and clamp the next layer. Make sure you use the 1 inch dimension of the spacer to make the channel. Again pick the cleanest and sharpest corner and place it so that it is near the center of the base. Clamp with as many as necessary. Again check for glue seeping on the base into the channel we will be making with the layers. You do not want it to dry so that the sliders are caught on them. Assure that the slider is snug between the two squares and that the squares are still aligned with the starting edge you clamped on earlier. Make sure to do this as soon as you have clamped the pieces as sometimes the clamps will twist the middle layer squares. The glue does dry quickly is some cases. Mine is suppose to be set within an hour but I have found that it holds the layers well within minutes. You will want to correct any mistakes quickly.
3) Using the straight edge and the sliders place the third layer similar to the second with the best corner towards the center and keeping glue out of the channel. Check alignment before and after clamping.
4) For the last piece you can ditch the straight edge and just use the two bottom layer sliders. Again place the best corner towards the center. Glue, clamp in place and assure that the sliders are snugly in the channel but still able to slide. Clean up any loose glue and wait for the glue to set.
'*"You may notice that aside form the first corner you glued the rest do not align as well. Do not attempt to correct this. You want to first assure that the inner channel is the correct dimension before you worry about the outside dimension which is less important. We will clean this up later.
*"After the glue is set remove the clamps and check to make sure the sliders fit within the resulting channels. If the sliders are too loose or tight start over again and be careful while gluing and clamping to not hit the clamps so much that the layers are shifted. Remember you want the slider to be snug but no so that movement is inhibited."
*"If any glue has been missed and allowed to dry in the channel remove it with a knife or sand paper now."
Add Comment
